How to Replace a Droid X Screen By :Robby
This is a discussion on How to Replace a Droid X Screen By :Robby within the Droid X Help forums, part of the Droid X Discussion category; Originally Posted by leighwarren Ok... so I used this video along with some other info to replace my cracked screen. Everything seemed to go pretty ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 11 of 11
Thread: How to Replace a Droid X Screen By :Robby
    Quote Originally Posted by leighwarren View Post
    Ok... so I used this video along with some other info to replace my cracked screen. Everything seemed to go pretty smoothly and even though I was crazy nervous, I felt like I did everything just like I was "instructed". When I was, what I thought as finished, and turned the phone back on, nothing happened. I then thought that maybe the battery needed a charge, so I plugged the phone up. When I did that it gave me the little vibrate/buzz thing it does when you unlock the phone. At that point I realized that it was in fact on, but nothing was coming up on the lcd... Now what do I do to get my picture back, or is it even possible? It was working fine beforehand... actually, other than the the spider-webbed glass being impossible to see through sometimes, the phone worked great. I was starting to have trouble with texting the day before i changed the glass, but everything else worked fine! HELP!
    Know this is an old thread, but I was having this same problem. The disassembly was easy enough, but now I couldn't get either my original screen or the new screen to turn on. The OP didn't mention it until the assembly vid, but there's a very fragile white clip that holds the ribbon cable to the LCD in place. You can see it at the end of his left thumb at 5:03. In my case, the white clip was not making a secure connection between the socket and the ribbon cable. I tried several remedies before I found one that worked. I took a piece of very sticky tape (3/8" wide) and rolled it up tightly so that it created a roll of tape about 1/8" diameter and 3/8" long. I placed this on top of the white socket, and took another piece of 3/8" wide tape (this time maybe 1/2" long) and taped it over the 1/8" x 3/8" tape roll and adhered it as tightly as I could to the circuit board. This put sufficient pressure on the socket to make a connection. It's working atm, so we'll see how it holds up.
  1. Replies: 3
    Last Post: 12-25-2010, 11:17 AM
  2. Will VZW replace my phone if there is a massive soft spot on my screen?
    By hijackerjack in forum Droid X General Discussion
    Last Post: 12-02-2010, 08:19 PM
  3. Wife lost Droid X - cheapest way to replace?
    By A guy with a phone in forum Droid X General Discussion
    Last Post: 10-19-2010, 06:45 PM
  4. Can the Droid X replace my iPod touch?
    By DXDrake in forum Droid X Help
    Last Post: 10-12-2010, 08:10 AM
  5. DROID X - Remove and Replace Google Account
    Last Post: 07-23-2010, 11:48 AM
droid x replacement screen
droid x screen
droid x screen repair
droid x screen replacement
how to replace droid x screen
how to replace screen on droid x
replacement screen for droid x
replacing droid x screen
