Amazon can't be killed?
This is a discussion on Amazon can't be killed? within the Droid X Help forums, part of the Droid X Discussion category; I just used Titanium Backup to freeze a long list of apps. Amazon mp3 was one of these, and I got the message that it ...
Results 1 to 10 of 17
Thread: Amazon can't be killed?
    Points: 2,426, Level: 29
    Level completed: 84%, Points required for next Level: 24
    TeeX's Avatar
    19502
    191
    I just used Titanium Backup to freeze a long list of apps. Amazon mp3 was one of these, and I got the message that it "has been frozen and will be invisible in my app drawer."
    However, I still have it listed in my app drawer. It's NOT invisible. When I try to start it, it of course said an error had occurred, so it's not operable, but I'd like it to be invisible. Out of sight, out of mind, I guess.
    I've rebooted twice, but it's still there. Taunting me with it's presence...
    Points: 6,135, Level: 50
    Level completed: 93%, Points required for next Level: 15
    Overall activity: 2.6%
    500 Experience PointsCreated Album pictures250 Experience Points100 Experience Points7 days registered
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    Do you use launcher pro or adw? Is so try hiding it it one of those.
    Addicted to technology but don't always get it!
    X 2
    Advocate X
    Points: 24,548, Level: 95
    Overall activity: 31.6%
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    You have to restart your launcher or your phone.
    {{ WugFresh }}
    Other helpful resources:
    TeeX's Avatar
    19502
    191
    Quote Originally Posted by WugFresh View Post
    {{ WugFresh }}
    Yeah, I've done this. Restarted the phone two different times, as well as do a battery pull. Still there.
    I'm only using the stock launcher that came with the DX. Is there a way to restart that launcher?
    Points: 3,746, Level: 38
    Level completed: 64%, Points required for next Level: 54
    xrazedx's Avatar
    15299
    875
    24 times
    I don't think the stock launcher will allow you to remove it from the app drawer. You need to use a launcher like lpp or adw.
    Swyped n sent from my X
    Rooted Droid X
    Overclocked at 1.35 GHz
    A man should look for what is, and not for what he thinks should be.
    -Albert Einstein
    For anyone interested in undervolting, read Undervolting Guide.
    Advocate X
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    Try and restore it, then download the latest updates for it, then freeze it. Alternatively, if its really giving you trouble you can always use a file explorer like root explorer to rename the file from amazon.apk to amazon.apk.bak
    The file is located in /system/apps
    {{ WugFresh }}
    xrazedx's Avatar
    15299
    875
    24 times
    ^^^Try what he said first but if I remember, I couldn't get Amazon mp3 to be removed from the stock app drawer either. That was a long time ago though.
    Rooted Droid X
    -Albert Einstein
    TeeX's Avatar
    19502
    191
    {{ WugFresh }}
    OK, I "defrosted"/restored it, updated it from the market, clicked "wipe data", and froze it again. Still, it persists, being visible in my app drawer. It's not a huge deal, but I'm curious why this one app is impervious to this process, where all others are froze and invisible.
    Don't know if I want to risk the root explorer, as I'm not real confident in myself getting that deep at this point.
    I've considered installing one of the launcher's mentioned, but I've heard that these launchers run on top of the stock launcher, so my phone will have two launchers running at the same time? Won't that create additional drag, as well as battery burden?
    thoughts? launcher recommendations?
    Points: 4,977, Level: 45
    Level completed: 14%, Points required for next Level: 173
    Overall activity: 1.0%
    gunner1982's Avatar
    25150
    ohio
    1,090
    18 times
    I used a app called uninstaller for root it gives u the option to back it up then remove it and then if u ever need to reinstall it just use an app installer mine worked fine
    Sent from my DROIDX
    Advocate X
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    @TeeX
    Root explorer is just a file explorer, like on any computer. All you are doing is going to the directory with all the system apps and renaming the file so that it has .bak extension, android will no longer consider it an app until you rename it back to apk. It's really not complicated at all, or dangerous in anyway.
    As far as alternate launchers are concerned; once you download and install one, the next time you hit the home button it will ask you what launcher you want to use. Once you set it as your default.. your stock launcher never runs.
    {{ WugFresh }}
  1. Replies: 41
    Last Post: 01-22-2011, 12:53 AM
  2. Rooted Phone, Liberty may have killed
    By MarkEnCU in forum Droid X Rooted Issues
    Last Post: 01-15-2011, 05:08 PM
  3. Rooted Phone, Liberty may have killed
    By MarkEnCU in forum Droid X Help
    Last Post: 01-15-2011, 12:53 PM
  4. Replies: 2
    Last Post: 01-13-2011, 09:35 PM
  5. I killed my DX
    By PhDCow in forum Droid X General Discussion
    Last Post: 09-03-2010, 03:17 PM
amazon appstore droid x freezing
droid x amazon mp3 remove
hide amazon app store drawer invisible
how can i get rid of amazon mp3 app on my droidx
how to delete amazon mp3 from droid x
how to stop freezing of of amazon mp3 app on motorola android x2
remove amazon mp3 from droid x
stop amazon download droid x 2
titanium backup pro freeze stopped
titanium cannot freeze amazon mp3
