Installing rom help!!!
This is a discussion on Installing rom help!!! within the Droid X Help forums, part of the Droid X Discussion category; I am trying to install a rom on my dx. I have gotten to the point where I choose the rom zip and reboot. I ...
Results 1 to 8 of 8
Thread: Installing rom help!!!
    Points: 1,764, Level: 24
    Level completed: 64%, Points required for next Level: 36
    Musicman's Avatar
    19665
    228
    I am trying to install a rom on my dx. I have gotten to the point where I choose the rom zip and reboot. I have the darkslide 4.2 rom folder on my sdcard but I don't know what to choose within that folder for the zip its asking for. Please help
    maddog0331's Avatar
    19947
    338
    7 times
    Quote Originally Posted by Musicman View Post
    First of all, are you rooted?...If not you have to be rooted to install themes and ROM. There are some good guides in this forum so just make sure to follow them. Also, the instructions for each released ROM are in the original post. So just make sure that you follow those directions to the point and always make a back up before you install anything. Hope this helps
    "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!
    Eleanor Roosevelt, First Lady of the United States, 1945"
    Musicman's Avatar
    19665
    228
    I am rooted. I am trying to follow the instructions as close as possible, but it just says select the darkslide zip. I downloaded the folder but don't know what zip in that folder I should choose. And thankfully I do have a backup.
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    the whole ROM is a zip, you should see install zip from sd then choose zip then the ROM towards the bottom of the list
    3 months registered100 Experience Points31 days registered7 days registered
    fe1111's Avatar
    25997
    6
    Thanks!
    Musicman's Avatar
    19665
    228
    When I click on the rom I get 3 options: meta-inf, sdcard, and system.
    Musicman's Avatar
    19665
    228
    I think I figured out my problem. I think the file is already unzipped and stored as a folder instead of a zip. Looks like its backup time
    1KDS's Avatar
    3981
    6,904
    573 times
    Yeah, it will only load as a zip, you shouldn't unzip it with the pc or the DX, just get the zip on your sd card
  1. Need Help Installing Bootstrap
    By omnicious in forum Hacking Help
    Last Post: 05-03-2011, 04:56 PM
  2. Help installing apex
    By jeebuss1 in forum Droid X ROMs
    Last Post: 01-03-2011, 02:03 AM
  3. I'm stumped after installing my first ROM which was UD RC2
    By 2outspoken in forum Droid X Hacks
    Last Post: 12-28-2010, 04:48 PM
  4. Need help installing rom?
    By Apocalypse in forum Droid X ROMs
    Last Post: 11-20-2010, 04:25 PM
  5. Having problems installing apk..
    By Tx_Cat in forum Droid X Apps
    Last Post: 10-03-2010, 02:52 PM
when installing jedi rom do you choose meta inf or system?
