Rooted and want to return to stock to do OTA updates and go to 2.2
This is a discussion on Rooted and want to return to stock to do OTA updates and go to 2.2 within the Droid X Help forums, part of the Droid X Discussion category; xxxxx...
Thread: Rooted and want to return to stock to do OTA updates and go to 2.2
    Points: 900, Level: 15
    Level completed: 50%, Points required for next Level: 100
    1 year registered100 Experience Points3 months registered31 days registered7 days registered
    jdmbb486's Avatar
    25535
    x
    xxxxx
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    if you know what you deleted and youre NOT on a leaked version on 2.2,
    [HOW TO] Reinstall Deleted System Apps/Bloatware
    if you are on a leaked 2.2 or cant remember all the mods you did,
    http://www.droidxforums.com/forum/dr...ing-guide.html
    and use the 2.3.15 sbf
    Points: 4,474, Level: 42
    Level completed: 62%, Points required for next Level: 76
    idontliketolose's Avatar
    19321
    425
    18 times
    When u attempt to install the ota update it will flash a "!". When you see that push the search button and it will show you the .apk that is missing which you need to download.
    Sent from the VorteX!
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Quote Originally Posted by jdmbb486 View Post
    Problem is I don't remember what I deleted and I'm still on the original 2.1...........
    If you follow Abe's directions above and follow the SBF Flashing Guide, you'll be fine...
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    The SBF will fix it. You are hitting the search key at the wrong time. Once the file downloads and you start to install it you will be in stock recovery, hit the search key at this point., it will show you the apk that is missing, chances are there are several.
  1. Return to stock
    By HeartAttackJeffrey in forum Hacking Help
    Last Post: 01-07-2011, 06:36 PM
  2. Noob help with rooted updates
    By raydude in forum Hacking Help
    Last Post: 12-30-2010, 05:35 PM
  3. Replies: 6
    Last Post: 10-30-2010, 12:47 PM
  4. Where can I get stock ota 2.2 detoxe and rooted?
    By AdamTomaino in forum Droid X ROMs
    Last Post: 10-27-2010, 06:15 AM
  5. Return to stock?
    By Hoax55 in forum Droid X Themes
    Last Post: 09-28-2010, 09:52 PM
droid 2 return to stock
droid2-back-to-stock-2-2
how to return droid 2 to stock
required apps for ota upgrade
return droid x to stock
return rooted droid to stock
return rooted droidx to stock
returning rooted droid stock
stock apps needed to ota update droid 3
stock apps needed to update droid 3 ota
want to uninstall the ota update
what stock apps do i need to update my droid x
will returning to stock remove my apps
will rooted droid x receive ota updates
