Freeze blur services
This is a discussion on Freeze blur services within the Droid X Help forums, part of the Droid X Discussion category; If I'm using launcher pro could I freeze all the moto blur services on my phone without negative effects? Sent from my DROIDX using Droid ...
Results 1 to 10 of 11
Thread: Freeze blur services
    Points: 1,764, Level: 24
    Level completed: 64%, Points required for next Level: 36
    Musicman's Avatar
    19665
    228
    Points: 46,436, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,088
    243 times
    Sure you can, but Launcher Pro has nothing to do with freezing apps, to do that you need Titanium Backup Pro.
    Advocate X
    Points: 24,548, Level: 95
    Overall activity: 31.6%
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    I don't recommend freezing all the blur. Don't freeze Backup Assistant. You should search for what apps are acceptable to freeze/rename to bak. Search for removing the bloatware.
    Your better off getting a blurless ROM and then adding blur vs getting a blur ROM and then removing blur.
    {{ WugFresh }}
    Other helpful resources:
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    You can hide them with launcherPro, if that's what you're asking
    Advocate X
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    Yeah. True. What exactly is it your trying to do?
    {{ WugFresh }}
    Musicman's Avatar
    19665
    228
    Since I'm not using blur I would like to stop it from running in the background and using battery. I'm aware I need to use titanium to freeze the apps. My reference to launcher pro was just to say that I'm not using blur. Thanks for the help.
    Advocate X
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    Why not just make a backup and load a blurless ROM?
    [HOW TO] Be ready for anything
    {{ WugFresh }}
    Points: 1,722, Level: 24
    Level completed: 22%, Points required for next Level: 78
    trabo's Avatar
    23585
    Los Angeles
    64
    Quote Originally Posted by Musicman View Post
    You're a perfect candidate to root your phone. Check out Roooler's guide. Do some reading and research, find out what you're doing. It's amazingly simple.
    You can be rooted in less than 2 minutes, remove the blue in another 5... and be on your way to completely customizing your phone. (Not to mention speeding it up and reducing battery usage!)
    Advocate X
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    +1
    {{ WugFresh }}
    Musicman's Avatar
    19665
    228
    I probably should have mentioned that I'm already rooted. I didn't want to remove the blur in case i need it for a future OTA. I figured if I use titanium I could just unfreeze later if I needed to. I really appreciate all of your help. A blurless ROM maybe my best bet. I'm just hesitant to try since I have never installed a ROM. Any advice on that would be welcomed a well
  1. Replies: 1
    Last Post: 12-17-2010, 09:10 PM
  2. Replies: 72
    Last Post: 12-11-2010, 07:56 AM
  3. Why does my X Freeze ?
    By GrinReaper in forum Droid X General Discussion
    Last Post: 10-08-2010, 04:20 PM
  4. Blur services can't be force stopped?
    By HillObserver in forum Droid X Help
    Last Post: 09-28-2010, 03:50 PM
  5. Why does my phone freeze up so much?
    By AC LINKS in forum Droid X General Discussion
    Last Post: 09-21-2010, 12:00 PM
droid x freeze motoblur
freeze adservice
freeze blur
freeze blur apps
freeze moto launcher
freeze motoblur
freeze motoblur for more performance
freeze motoblur for more performance and ram
freeze motorola services
titanium backup freeze motoblur
