how to select a shorter backlight duration
This is a discussion on how to select a shorter backlight duration within the Droid X Help forums, part of the Droid X Discussion category; apparently making a back-light duration less it conserves battery. How do I alter that?...
Results 1 to 2 of 2
Thread: how to select a shorter backlight duration
    droidxer's Avatar
    2511
    106
    Points: 5,228, Level: 46
    Level completed: 39%, Points required for next Level: 122
    thescreensavers's Avatar
    268
    Miami,FL
    464
    48 times
    Settings> Sounds& Display > Scroll way down for Brightness
    But be aware if you set it really low, the phone wont automatically bring it back up when you get in the sun.
    Droid Does
  1. DROID X - Select Ringtone, Volume, Vibrate
    Last Post: 08-22-2010, 08:54 PM
  2. Returning X Cant adjust backlight
    By george1974 in forum Droid X Help
    Last Post: 07-26-2010, 07:25 PM
backlight ipad timer
backlight timer ipad
change backlight timer ipad
how to adjust backlight on ipad 2
how to change backlight time on ipad
how to change backlight timer on ipad
how to set backlight time on ipad
ipad 2 backlight timer
ipad backlight settings
ipad backlight timer
