Yahoo Mail Notification
This is a discussion on Yahoo Mail Notification within the Droid X Help forums, part of the Droid X Discussion category; I am using Yahoo Mail through the Market's Yahoo App. I am looking for a way to put an audio notification on this when email ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Droid-Xer
Thread: Yahoo Mail Notification
    Points: 1,000, Level: 16
    Level completed: 50%, Points required for next Level: 100
    Grndcomm's Avatar
    22592
    Duncan, SC
    13
    I am using Yahoo Mail through the Market's Yahoo App. I am looking for a way to put an audio notification on this when email arrives. Currently it is vibrating only. I sent an email to my gmail account and got an audio notification. I have looked all over the Yahoo app and have not seen an option to change this notification. Any help appreciated
    grndcomm
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Open the app, push the menu hard key and go to settings/preferences and select notifications
    Grndcomm's Avatar
    22592
    Duncan, SC
    13
    When I open the Yahoo Mail app, press the hard menu key I am presented with the following: Compose, Search, Refresh, Messenger, Options, and More. Under Options I see the following: General Settings and my email address. Under General Settings I have Notification sounds (says under this one " Use sound and vibrate when mail arrives") which can be either checked or unchecked. poor picture, but maybe helpful
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Give me a sec. Let me download app.
    Grndcomm likes this.
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Ok, if you have it checked, then you should be getting audible notification. Are you on a stock phone?
    Grndcomm's Avatar
    22592
    Duncan, SC
    13
    Yes, received phone from Verizon last week. I did find out that if I login to Yahoo messenger, I do get a sound. I did not choose this sound and don't know where to change it, but it did produce a short tone when an email arrived. I am not active on Yahoo messenger, but if that is what it takes I guess I will have to keep that going.
    Have an early wake up tomorrow so I am shutting down for the evening. Thanks for your respones and I'll check back tomorrow evening.
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Ok. FYI if you have more than one email account you can use an email client like k9 to consolodate them into one. It also has better notification settings then stock apps.
    Grndcomm's Avatar
    22592
    Duncan, SC
    13
    I will try the K-9 you mentioned. Appreciate the time you gave me on this issue.
    grndcomm
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Sure thing!
    Points: 4,929, Level: 44
    Level completed: 90%, Points required for next Level: 21
    BambamNJ's Avatar
    38265
    How to change Notification Setting On the Yahoo App for Droid
    I tried the Hard Press Menu that was mentioned earlier and either my phone is different or I am not doing something right because I don't get a menu that has any kind of settings option on it
    Here is how I did this.
    open the Yahoo App and go to one of your email accounts
    On the top of the screen there is an ICON that looks like three lines (it's next to the word "Inbox")
    Press this and you should get a listing of all of your folders you have in this email account
    Scroll down to the bottom of the list and you will see an option called "Settings"
    click settings and you will see a list of all of your emails with the words "Account Settings" above each one
    Pick one and select "Account Settings"
    the first option that shows is "Notification Settings"
    press this
    Now you can "Choose A Sound" or turn on/off the vibrate option
    Make sure you click "DONE" at the bottom to save your choice of Sound.
    Once you make the change hit the Back Key on your phone and you can select another email to change
    Hope this helps someone out there
  1. Yahoo mail notifications - disable
    By DrewCrewOf2 in forum Droid X Help
    Last Post: 12-16-2010, 12:00 PM
  2. Yahoo mail version 1.2.0
    By Slyther83 in forum Droid X Apps
    Last Post: 10-27-2010, 09:31 AM
  3. Yahoo IM notification
    By nm6r in forum Droid X Apps
    Last Post: 10-09-2010, 06:51 PM
  4. Forwarding yahoo mail
    By kziegenmier in forum Droid X Help
    Last Post: 09-10-2010, 01:52 PM
  5. yahoo mail multiple accounts HELP!
    By art in forum Droid X Help
    Last Post: 08-15-2010, 01:05 PM
android yahoo mail notification sound
change notification sound yahoo mail app android
how to change message audio tone on yahoo mail
how to change notification on yahoo mail app
how to change yahoo email notification sound on android
how to change yahoo messenger notification sound on android
yahoo mail android ringtone
yahoo mail app notification sound
yahoo mail app ringtone
