Phone went into safe mode (no clue why)
This is a discussion on Phone went into safe mode (no clue why) within the Droid X Help forums, part of the Droid X Discussion category; My phone was freezing up and I had to take out the battery as I have in the past. When I put it back in ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Phone went into safe mode (no clue why)
    droidxer's Avatar
    2511
    106
    My phone was freezing up and I had to take out the battery as I have in the past. When I put it back in it went into safe mode with a background I used months ago. Not sure why safe mode went on or the old background shows.
    How do I get back to regular mode?
    Points: 35,547, Level: 100
    Overall activity: 42.3%
    1KDS's Avatar
    3981
    6,904
    572 times
    there should be a reboot option, use the volume keys to move and the camera to select
    I posted in your other thread about factory reset, this should take care of it
    droidxer's Avatar
    2511
    106
    Thanks I will try that but for now can't get out of safe mode. Tried a bunch of things.
    1KDS's Avatar
    3981
    6,904
    572 times
    It won't reboot when you select it? What does the screen say?
    droidxer's Avatar
    2511
    106
    Camera function and volume work normally in safe so not sure about ur suggestion.
    1KDS's Avatar
    3981
    6,904
    572 times
    What do you mean by safe mode? Not recovery?
    abcstyers's Avatar
    22866
    6
    Quote Originally Posted by droidxer View Post
    I'm pretty sure you have to hold the power and home buttons at the same time to bring up that menu. Then you should use your volume rocker to select the re-boot option
    droidxer's Avatar
    2511
    106
    Just did a factory re-set still says "Safe Mode" in bottom left corner.
    1KDS's Avatar
    3981
    6,904
    572 times
    shut it off, hold down home when booting back up, when the triangle pops up with an exclamation point hit the search key, you will be in recovery, select wipe data and wipe cache partition then reboot
    droidxer's Avatar
    2511
    106
    How is that different from the factory reset? If I go through those steps that will get me out of safe mode? Will I still be able to dial and make calls basic functionality or would I need to go back to the store?
    Why did it go into Safe Mode altogether could it be compromised or dirt got in and it will never be able to be restored?
  1. Replies: 316
    Last Post: 06-17-2011, 11:12 PM
  2. Safe Mode
    By theNet in forum Droid X Hacks
    Last Post: 12-14-2010, 12:45 PM
  3. Replies: 128
    Last Post: 12-02-2010, 06:38 PM
  4. Transfer iPhone contacts to the Droid X.. any clue how?
    By robinmathew in forum Droid X General Discussion
    Last Post: 07-28-2010, 04:00 PM
disable droid x safe mode
disable safe mode droid x
droid x safe mode fix
droid x safe mode get out of safe mode
how do i get my droid out of safe mode
how do i get my droid x out of safe mode
how to get droid out of safe mode
how to get droid x out of safe mode
why is my droid in safe mode
why is my phone in safe mode
