Help syncing music via doubletwist
This is a discussion on Help syncing music via doubletwist within the Droid X Help forums, part of the Droid X Discussion category; Since I have a ipod touch I have a lot of music on itunes. So I looked around and saw ppl recommending doubletwist. I downloaded ...
Thread: Help syncing music via doubletwist
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    Question Help syncing music via doubletwist
    Since I have a ipod touch I have a lot of music on itunes. So I looked around and saw ppl recommending doubletwist. I downloaded it on both my X and my PC and when I go to sync the files wont sync. It goes through the process but then says "Files skipped" which ends up being them all. No I have not bought them all from itunes. I use Vuze and then add them to itunes.
    Any suggestions?
    Thanks!
    EDITED: Nevermind! I figured it out. Go figure when I finally post I get it!! LOL
    Thanks anyways!
    Droid Does!!!
    issues with syncing X to DT
    What did you do to figure it out? I'm having the same issues. I sync all my music but only a fraction appear on my X and some of them either say "file doesn't appear anymore" or "device cannot play the supported file" even when the file is an .mp3.
    How did you figure it out?
    Quote Originally Posted by didiwags View Post
    Any suggestions?
    Thanks!
    Thanks anyways!
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Quote Originally Posted by Jason1234 View Post
    Welcome to the forum!!
    You can also try an app in the market called iSyncr - it will sync your playlists from iTunes or there is also iTunes Agent ( iTunes Agent )...
  1. Syncing with Outlook Contact & Calendar
    By pumpbubble in forum Droid X Help
    Last Post: 09-18-2010, 12:31 PM
  2. Contacts not syncing via Bluetooth
    By riguy in forum Droid X General Discussion
    Last Post: 07-19-2010, 11:50 AM
  3. Music app crash
    By Gregro in forum Droid X Help
    Last Post: 07-18-2010, 05:22 PM
  4. Gmail syncing problems
    By coasterman93 in forum Droid X General Discussion
    Last Post: 07-17-2010, 06:01 PM
  5. Help with Facebook syncing contacts...
    By nowski91381 in forum Droid X General Discussion
    Last Post: 07-15-2010, 05:37 PM
doubletwist doesn't sync
doubletwist doesn't sync all music
doubletwist doesn't sync all songs
doubletwist is not syncing
doubletwist not syncing
doubletwist not syncing all songs
doubletwist some files did not sync
how to use doubletwist
how to use doubletwist with droid
some files did not sync doubletwist
