droid x charger vs blackberry charger
This is a discussion on droid x charger vs blackberry charger within the Droid X Help forums, part of the Droid X Discussion category; This may be a dumb question, but my old storm charger fits my droid. Is there any harm in using it to charge my X ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Like Tree3Likes
Thread: droid x charger vs blackberry charger
    Points: 2,451, Level: 30
    Level completed: 1%, Points required for next Level: 149
    rubi22's Avatar
    396
    188
    11 times
    This may be a dumb question, but my old storm charger fits my droid. Is there any harm in using it to charge my X on a daily basis?
    Points: 3,573, Level: 37
    Level completed: 49%, Points required for next Level: 77
    Overall activity: 0.6%
    ajp's Avatar
    444
    SD
    223
    Shouldn't be. If you want to be sure, check the output voltages for both chargers to see if they're the same. I've been swapping chargers for quite some time Moto Q -> BB Curve....BB Tour -> DX and haven't noticed any problems.
    rubi22 likes this.
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    So the connector that fits both phones is called Micro USB and a lot of phone manufacturers are trying to standardize on that to help eliminate waste. The main thing to look at is not the voltage (this is standard for all of these) but instead is the current. Not all USB cables can push the same amount of current through and for THAT reason, not all chargers will be the same.
    Our Droid X charger pushes either 800 or 850mA (I forget). I have another charger that pushes 350mA and it's not enough for the phone. I'd expect 500mA would be the minimum you would want to do. It's okay to go higher as this is like the maximum amount the charger can handle, not necessarily the amount the charger shoves down the throat of the phone.
    rubi22 and anomaly like this.
    rubi22's Avatar
    396
    188
    11 times
    Ok perfect, thanks guys.
    31 days registered250 Experience Points100 Experience PointsTagger Second Class7 days registered
    freshgeardude's Avatar
    269
    86
    24 times
    my bb charger does 700ma. so im pretty sure it will work for my dx when i get it
    rubi22's Avatar
    396
    188
    11 times
    For the record:
    Droid X= 5.1V/850mA
    Storm 1=5V/700mA
    Should be alright
    Points: 5,228, Level: 46
    Level completed: 39%, Points required for next Level: 122
    thescreensavers's Avatar
    268
    Miami,FL
    464
    48 times
    ^ It is.
    I exclusively charge my Droidx on the Blackberry Storm's charger at night. I have had no problems and I been doing it since release day.
    Droid Does
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    As long as the current reading (800mA, 700mA, etc) is above the minimum required (I don't know what this is), it'll work. However, the higher it is, the faster the phone will charge. Note that this is not always a good thing. Lithium Ion batteries like being charged slowly and drained slowly. Faster charges are harder on them. However, I'm not sure it would convince me to use a 700mA over an 800mA charger, but it would convince me to stick with 1000mA (1A) or lower so it doesn't get a bit too excited about charging up quickly.
    Points: 2,131, Level: 27
    Level completed: 88%, Points required for next Level: 19
    -V-'s Avatar
    2449
    6
    Quote Originally Posted by Jaxidian View Post
    Can you please help me understand this? The lower the number (700mA, 800mA, 1000mA) the faster it charges?
    Thanks!
    This is great to know because the droid charger cord is way to short IMO
  1. Desktop Charger Cradle
    By mbern1008 in forum Droid X Accessories
    Last Post: 10-26-2010, 02:14 PM
  2. Car charger recommendations
    By Androidrookie in forum Droid X Accessories
    Last Post: 07-21-2010, 09:47 PM
  3. Droid X wall charger USB cable
    By DroidXXX in forum Droid X Accessories
    Last Post: 07-18-2010, 06:32 PM
  4. Battery Charger/Cable
    By dard12 in forum Droid X General Discussion
    Last Post: 07-16-2010, 04:18 PM
  5. Car Charger question
    By supahrob in forum Droid X General Discussion
    Last Post: 07-11-2010, 09:53 AM
blackberry charger droid x
blackberry charger fits droid
blackberry charger for droid x
blackberry charger on droid
blackberry charger with droid x
charging a droid with a blackberry charger
droid charger on blackberry
droid x blackberry charger
droid x charger for blackberry
droid x charger same as blackberry
