Power Control Widgets Override Restriction Lock
This is a discussion on Power Control Widgets Override Restriction Lock within the Droid X Help forums, part of the Droid X Discussion category; In reviewing some location based security settings I've found that when I enable the Location Restriction in Lock Restrictions (located under settings > location & ...
Thread: Power Control Widgets Override Restriction Lock
    xpnsvtoys's Avatar
    6294
    Winchester, VA
    In reviewing some location based security settings I've found that when I enable the Location Restriction in Lock Restrictions (located under settings > location & security settings) it will not allow you to turn on GPS through the locations & security settings page, however you can turn on the GPS using the stock Android Power Control widget or other third party power widgets. I am using a Motorola Droid X running the latest OTA update...
    Is there anyway to lock the GPS off, so it can not be turned on with a power control widget?
    Points: 68,684, Level: 100
    Overall activity: 5.4%
    250 Experience PointsYour first Group31 days registered100 Experience Points7 days registered
    wicked's Avatar
    15645
    San Jose CA.
    5,245
    727 times
    I'm not sure why you would want to lock GPS but if you don't want to accidentally turn it on, remove power conrol widget from your screen.
    Use a 3rd party widget like SwitchPro, and don't add GPS when setting the widget...
    xpnsvtoys's Avatar
    6294
    Winchester, VA
    Quote Originally Posted by wicked View Post
    Logical...Although not fail safe, at least not for my users...
    I've got many less than average Android users that will happily push buttons for the shear fact that they are there...I am trying to implement a location privacy policy, so as my users don't inadvertently post a pic, comment, etc and reveal their location at the wrong place/time. I was hoping something simple and built in like Location Lock Restriction would solve this, but I guess not. Any other ideas??
  1. need help with restriction lock
    By BoySetsTheFire in forum Droid X Help
    Last Post: 09-23-2010, 09:45 AM
  2. Replies: 1
    Last Post: 08-30-2010, 04:10 PM
  3. power control vs switchpro
    By medicscott in forum Droid X Apps
    Last Post: 08-08-2010, 12:17 AM
  4. Replies: 1
    Last Post: 08-03-2010, 08:41 AM
  5. Power control widget
    By anomaly in forum Droid X General Discussion
    Last Post: 07-22-2010, 11:05 AM
Droid x restriction password
android restriction lock
droid x restriction lock
droid x restriction lock default password
location restriction enabled droid x
location restriction is enable
location restriction is enabled
restriction lock
restriction lock android
restriction lock droid
