Voicemail button in Dialer..not taking my password input
This is a discussion on Voicemail button in Dialer..not taking my password input within the Droid X Help forums, part of the Droid X Discussion category; I inputted my ,pause,pause, and vmail password in my Voicemail settings, but when I click on the voicemail button next to the call button in ...
Results 1 to 7 of 7
Thread: Voicemail button in Dialer..not taking my password input
    Points: 2,024, Level: 27
    Level completed: 16%, Points required for next Level: 126
    spyder560's Avatar
    354
    102
    click on the voicemail button next to the call button in Dialer, it still only dials *86 and does not auto enter my password.
    Anyone else figure out a fix for this?
    Points: 1,623, Level: 23
    Level completed: 23%, Points required for next Level: 77
    JK-X's Avatar
    75
    Erie, Pa
    80
    Having the same problem. Just figured I was doing something wrong.
    Points: 1,640, Level: 23
    Level completed: 40%, Points required for next Level: 60
    250 Experience PointsTagger Second ClassCreated Album pictures100 Experience Points7 days registered
    seapup's Avatar
    537
    Northern VA
    208
    15 times
    Sounds like either your pause character is hosed or you forgot to enter the trailing pound sign. Try this...
    Pull up your contacts
    Scroll down to Voicemail and select it
    Push the hard Menu button
    Select Edit
    Enter *86,,123456# (where ,, are two comma characters and 123456 is your password)
    Select Save
    If you don't want your phone to automatically send the password, thus prompting you for the go-ahead, replace the commas with one semi-colon ;
    spyder560's Avatar
    354
    102
    Quote Originally Posted by seapup View Post
    Select Edit
    Select Save
    Nope, that's exactly what I have both in the Contact and in the Voicemail Settings
    100 Experience Points3 months registered31 days registered7 days registered
    sneakypeter11's Avatar
    14914
    I have this same problem. Any fix yet?
    Points: 398, Level: 7
    Level completed: 96%, Points required for next Level: 2
    BigShowJoe's Avatar
    35294
    6
    Bump.
    Points: 370, Level: 7
    Level completed: 40%, Points required for next Level: 30
    Hawkster's Avatar
    35597
    I have a simple work around since I too had the same issue.
    1) Create a separate contact called Voicemail. Enter the *86,,XXXX# for the phone number. (XXXX is your password). Save the contact.
    2) Create a "Quick contact" in the Motorola widgets using the voicemail contact you created on the same page as your voicemail icon.
    3) Modify the quick contact to the size and add a picture if you would like. ( I took a picture of the voicemail icon and tweaked it to fit).
    4) Delete the voicemail icon from the page it was on and replace it with the Quick contact.
    Kind of a clunky way to get around it, but effective, until someone here with better knowledge can figure out why the built in app is not cooperating.
  1. Voicemail settings for password...how?
    By spyder560 in forum Droid X General Discussion
    Last Post: 04-14-2011, 01:51 PM
  2. status indicator led blinks when pressing pwr button
    By pwrdbykyank in forum Droid X General Discussion
    Last Post: 11-26-2010, 07:27 PM
  3. why is there no stock t9 dialer!!!!???
    By ucla2042 in forum Droid X General Discussion
    Last Post: 07-22-2010, 04:34 PM
  4. input on a good clock app
    By DroidBlazer00 in forum Droid X Apps
    Last Post: 07-16-2010, 09:38 AM
  5. USER CP Button when viewing threads
    By sphen22 in forum New Member Introductions & Site Assistance
    Last Post: 07-14-2010, 10:37 PM
droid voicemail password not working
droid x2 voicemail not working
droid x2 voicemail password
galaxy s2 voicemail password
verizon voicemail not accepting password
verizon voicemail not recognizing password
verizon voicemail not taking password
verizon voicemail password not working
