Need to unroot, no nandroid backup, installed rom.
This is a discussion on Need to unroot, no nandroid backup, installed rom. within the Droid X Help forums, part of the Droid X Discussion category; I rooted using doroot and followed the instructions below. I have installed roms/themes. I did not do the nandroid backup prior to installing the theme ...
Thread: Need to unroot, no nandroid backup, installed rom.
    250 Experience Points100 Experience Points31 days registered7 days registeredTagger Second Class
    jonsgirl's Avatar
    12715
    73
    I rooted using doroot and followed the instructions below. I have installed roms/themes. I did not do the nandroid backup prior to installing the theme because even though I thought I thoroughly researched before I rooted I missed this crucial step. Is it possible to unroot now and if so how?
    A. ROOT FIRST : Without rooting your Droid X, you will not be able to access the restricted files that are normally locked on your stock DX and will not be able to make any modifications to your DX)
    B. CONFIRM THAT ROOT HAS WORKED: you can check this by making sure that an app called “Superuser Permissions” has installed in your app drawer.
    C. DEODEX YOUR FROYO: don’t worry about what this really means…just know that it’s necessary for the custom ROMs to function with respect to changing fonts, widgets, frame appearance, etc. If you want a real explanation, google it…as I’ve said before there are hundred and thousands of forums dedicated to explaining what this actually does. Without deodexing your Droid X (or any other android-based platform) you will most likely not be able to install any of the current custom ROMs and themes that are available for download.
    D. Download and install ONLY DEODEXED ROMs (or Themes) using BOOTSTRAP APP. If you try to install a ROM that is not deodex compatible you will brick your phone. I have directions to unbrick your phone at the end of this manual.
    Points: 15,509, Level: 80
    Level completed: 32%, Points required for next Level: 341
    Overall activity: 7.1%
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    Why do you need to unroot?
    To accept the update? Root is not going to be a problem, but if you have rommed and themed it without a stock backup, you will probably need to sbf back to stock to update.
    I feel like a broken record lately.
    Sent from my DROIDX
    jonsgirl's Avatar
    12715
    73
    Thank you for your help. I read and read before asking but couldn't find an exact answer so figured better to ask before I screwed it up.
  1. Clockwork mod recovery - Nandroid backup
    By johnnysyeah in forum Droid X Apps
    Last Post: 12-05-2010, 10:31 PM
  2. Replies: 3
    Last Post: 10-19-2010, 05:41 PM
  3. Using nandroid Backup?
    By ColdSteele in forum Hacking Help
    Last Post: 09-19-2010, 04:47 PM
  4. nandroid backup invisible
    By dmarth10 in forum Droid X Help
    Last Post: 09-05-2010, 04:21 PM
  5. Clean Nandroid Backup
    By taypotts in forum Droid X Hacks
    Last Post: 08-20-2010, 02:53 AM
did rom update without nandroid back up help?
do you have to have a nandroid backup to unroot
do you need nandroid backup if stock rom
droid x stock backup rom download
droid x stock rom download
droid x stock rom nandroid backup
hot to unroot android no backup
nandroid backup rom runterladen
nandroid backup senza root
nandroid backup without root
nandroid download droid x
no nandroid backup
rooted without backup
stock droid x rom download
unrooting with no nandroid
