ok so I have seemed to have fixed the slowdown issues I have had now I need some help with overclocking. I have been using milestone overclocker and setcpu and I want to knew what I can do to get the best performance with good battery life. im just wondering on some good setups that some of you guys are using are and if you could help me set up my droid that way. thanks
