Did you change the speed on the sliders?
This is a discussion on overclocking help within the Droid X Help forums, part of the Droid X Discussion category; Did you change the speed on the sliders?...
yes I had it all set up with all four settings on the profile. it keeps changing back to default settings and will stay at 300mhrz until I change it. I am using setcpu to keep the settings running but it seems that the built in profile setup in jrummys is better it just wont keep set. anyone have some advice?
there might be conflicting info between set CPU and jrummys app. If you have TiBackup then freeze setCPU and try it now.
no see that's the thing its working with set cpu. it keeps reseting if I use it by itself
