You should use ForgetBox
Its Android app enables you to send files by e-mail or SMS much more easily. So much easier than Gmail: there is no limits of size.
This is a discussion on Problems with GMail app and stuck sending "large" files/attachments within the Droid X Help forums, part of the Droid X Discussion category; You should use ForgetBox Its Android app enables you to send files by e-mail or SMS much more easily. So much easier than Gmail: there ...
