928droid bgx. Wanna change bat icon and...
This is a discussion on 928droid bgx. Wanna change bat icon and... within the Droid X Help forums, part of the Droid X Discussion category; Text on lock screen. Tried finding how to do this to no avail. Ideally a battery icon w a percentage meter. Any help would be ...
Results 1 to 10 of 11
Thread: 928droid bgx. Wanna change bat icon and...
    NY_ROCKER's Avatar
    831
    134
    8 times
    Any help would be appreciated
    Points: 3,573, Level: 37
    Level completed: 49%, Points required for next Level: 77
    Overall activity: 0.6%
    ajp's Avatar
    444
    SD
    223
    I recommend WidgetLocker for custom lockscreens. Battery Left Widget sounds like what you want for your battery. I use both, they're both paid apps, but I think they're very worth the cost.
    MIUI 1.12.30
    proud X owner since launch day
    NY_ROCKER's Avatar
    831
    134
    8 times
    I was hoping to skin the existing battery charger icon instead of having 2. And does widgetlocker allow changing the on screen text?
    Points: 6,553, Level: 53
    Level completed: 2%, Points required for next Level: 197
    Overall activity: 1.5%
    jloya's Avatar
    12032
    1,444
    35 times
    check out droidpirate.com
    you can use metamorph to change battery icon
    as far as text on lock screeen i dont know if widget locker does that
    NY_ROCKER's Avatar
    831
    134
    8 times
    will do.. thanks.
    Yeah - I didn't think widget locker would allow that.
    ajp's Avatar
    444
    SD
    223
    I said WidgetLocker because it'll allow you to do *anything* you want to your lockscreen. It replaces the default VZW one. Check out the link below for some screenshots/info, maybe it'll do what you need. Otherwise, I know people have said "Executive Assistant" which is essentially the same thing but with a widget and welcome screen too. They mainly wanted to add the "In Case of Emergency..." info to their lockscreen, but I'm pretty sure there's a way to do that in WidgetLocker too. I don't use ExecAsst because I tried both it and WidgetLocker, and I liked WidgetLocker way better.
    WidgetLocker Lockscreen - Android app on AppBrain
    Android App Review: Executive Assistant - Droid Life: A Droid Community Blog
    MIUI 1.12.30
    ajp's Avatar
    444
    SD
    223
    Quote Originally Posted by jloya View Post
    Just checked out metamorph - thanks for the info. One more thing to mess around with!
    MIUI 1.12.30
    jloya's Avatar
    12032
    1,444
    35 times
    Quote Originally Posted by ajp View Post
    no problem
    it really allows you to customize your device beyond a theme and kind of create your own "theme"
    make sure to make a backup before flashing new things from there
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Also check out ninjamorph. I prefer that to metamorph.
    jloya's Avatar
    12032
    1,444
    35 times
    Quote Originally Posted by Droid-Xer View Post
    any particular reason?
  1. Rooted using z4 app and now i wanna be Unrooted
    By traviscw in forum Droid X Hacks
    Last Post: 11-16-2010, 10:37 AM
  2. Is there a way to change the icon for a folder?
    By 3elevenX in forum Droid X General Discussion
    Last Post: 10-23-2010, 06:25 AM
  3. Dx got wet and wanna return
    By cjacobs in forum Droid X Help
    Last Post: 09-10-2010, 09:44 AM
  4. I wanna know what all the fuss is about..
    By iDr0id in forum Off-Topic Discussion
    Last Post: 08-29-2010, 02:00 PM
  5. How to change Icon Docks on screen.
    By DolphinxManiax23 in forum Droid X Help
    Last Post: 08-28-2010, 09:41 PM
battery icon metamorph meter
droid x metamorph battery icon
