Created nandroid backup of old phone for replacement phone. Good or Bad?
This is a discussion on Created nandroid backup of old phone for replacement phone. Good or Bad? within the Droid X Help forums, part of the Droid X Discussion category; I just got my replacement DX (hardware issue - the bottom piece on the front where the mic is was loose). I thought an easy ...
Thread: Created nandroid backup of old phone for replacement phone. Good or Bad?
    Points: 2,349, Level: 29
    Level completed: 33%, Points required for next Level: 101
    250 Experience Points100 Experience PointsTagger Second Class31 days registered7 days registered
    bauerat02's Avatar
    10997
    Madison, WI
    50
    I just got my replacement DX (hardware issue - the bottom piece on the front where the mic is was loose). I thought an easy way to get all my apps, contacts, text messages, etc. over to the new phone was to create a backup of my old phone.
    Now when backup assistant runs, it says my PIN does not match MDN for this subscriber and to call Verizon Customer Support for assistance. Did I mess something up with putting the backup from my old phone on my new phone? Since backup assistant won't sync now, I am worried that some important identification numbers from my old phone are now on my new phone and might mess things up.
    Points: 23,980, Level: 94
    Level completed: 63%, Points required for next Level: 370
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    What did you use to create a nandroid backup? Backup assistant doesn't do nandroid backups and is pretty much useless IMO.
    You could use bootstrap to create a nandroid backup, and then root the new phone, install bootstrap, and restore your backup. The thing is, what problems were you having that caused you to get a new phone? Restoring your old phone might just transfer the problem to your new device, unless it was hardware-related.
    bauerat02's Avatar
    10997
    Madison, WI
    50
    It was just a hardware issue, the phone was working fine. I used the bootstrap to create the backup. Since backup assistant won't sync now, I am worried that some important identification numbers from my old phone are now on my new phone and might mess things up.
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    If the new phone is working properly otherwise, I wouldn't worry about backup assistant, it has never worked right for me. I think I've gotten those same errors before and it wasn't a problem, other than not being able to use backup assistant.
    Sent from my DROIDX
  1. Replies: 1
    Last Post: 07-26-2011, 11:59 AM
  2. what happens if you get a replacement phone how do you get your apps back?
    By fanyoo1 in forum Pending Submissions / Questions
    Last Post: 10-07-2010, 06:16 PM
  3. Replies: 4
    Last Post: 08-19-2010, 11:15 AM
  4. Do you think I should ask for a replacement phone?
    Last Post: 07-24-2010, 03:28 PM
backup assistant mdn changed
backup assistant pin does not match mdn
backup assistant pin dows not match mdn for this subscriber
backup assistant the pin does not match the mdn
nandroid backup on replacement phone
pin does not match mdn for this subscriber
restoring nandroid to new device
verizon backup assistant mdn changed
verizon pin does not match mdn
