Navigation map doesn't rotate when driving direction changes
This is a discussion on Navigation map doesn't rotate when driving direction changes within the Droid X Help forums, part of the Droid X Discussion category; I've just started using the Google maps/navigation thing in my car. But unlike my Magellan and Garvin, when I change the direction I'm heading, the ...
Results 1 to 10 of 19
Thread: Navigation map doesn't rotate when driving direction changes
    Points: 931, Level: 16
    Level completed: 31%, Points required for next Level: 69
    Gorgerax's Avatar
    9007
    WA
    9
    I've just started using the Google maps/navigation thing in my car. But unlike my Magellan and Garvin, when I change the direction I'm heading, the screen on the DX does not rotate so that the direction I am travelling is always at the top. Does anyone know if this can be setup somehow?
    Thanks!
    Points: 6,551, Level: 53
    Level completed: 1%, Points required for next Level: 199
    B360155's Avatar
    217
    North Richland Hills, TX
    389
    32 times
    Have you tried a battery pull? I have had that happen on rare occasions but the normal Google maps / turn by turn navigation works the same as what you're describing with the direction your car is traveling always pointing up.
    Points: 5,066, Level: 45
    Level completed: 58%, Points required for next Level: 84
    Overall activity: 1.5%
    31 days registered250 Experience PointsTagger Second Class100 Experience Points7 days registered
    gravybird's Avatar
    17670
    Balaton, MN
    1,116
    21 times
    The maps part only shows the map facing north, regardless of what way you're driving. I just open up the navigation icon and press the M icon on the top right corner, and that's just like running a garmin, and you don't have to put on a destination if you don't want to.
    Points: 113, Level: 2
    Level completed: 26%, Points required for next Level: 37
    BCool83's Avatar
    47424
    Sep 2011
    5
    Bumping this. I recently installed the rooted GB update. For several weeks after that, the Maps app worked perfectly...as of three days ago, now while navigating the display does not rotate - North is always up. There is no compass rose icon on which to click while navigating to switch from north-up to direction-up (though the compass rose does appear when just in regular maps mode). Any ideas on how to make nav rotate based on my direction of travel? I've done a battery pull already.
    Points: 1,514, Level: 22
    Level completed: 14%, Points required for next Level: 86
    MutantCheese's Avatar
    20578
    218
    8 times
    Google maps rotates as you drive so that the direction of travel is always up. The navigation app doesn't do that and it does get annoying.
    Samsung Galaxy Nexus
    Samsung Galaxy Tab 10.1 32 GB
    ​DX Apex 2.0 RC2 GB .596
    Moto Xoom wifi 32 GB - ReturnedSamsung Fascinate - shelved.
    HTC Incredible - Traded.
    DX2 - Returned.
    BCool83's Avatar
    47424
    Sep 2011
    5
    That's not true Mutant - at least not until 3 days ago for me.
    20578
    218
    8 times
    I just went for a drive and my Navigation in standard follow me mode did work properly by having my direction of travel up.
    DX2 - Returned.
    BCool83's Avatar
    47424
    Sep 2011
    5
    Dang... Maybe I'll try to update the app...or uninstall and reinstall
    Points: 48,761, Level: 100
    Overall activity: 17.2%
    gbrinn's Avatar
    38696
    Headed to Duke University Hospital
    17,707
    727 times
    Yeah, mine rotates as a "typical" GPS should. I've never had a problem with it at all.
    "Master of Puppets I'm pulling your strings / Twisting your mind, smashing your dreams
    Blinded by me, you can't see a thing / Just call my name, 'cause I'll hear you scream
    Master / Master
    " - Metallica
    Points: 71, Level: 1
    Level completed: 43%, Points required for next Level: 29
    Overall activity: 0.0%
    arungov's Avatar
    48341
    Sep 2011
    same issue here
    I just started facing the same issue. It was working fine for the past year. I tried pulling the battery. uninstalling the google map update. The navigation maps always point north. Is there a way to fix it ?
  1. Rotate dialer
    By iresq in forum Droid X Help
    Last Post: 09-28-2010, 08:26 PM
  2. Replies: 0
    Last Post: 09-16-2010, 03:08 PM
  3. Replies: 4
    Last Post: 07-30-2010, 08:42 PM
  4. Google Nav Display Direction
    By rolaur in forum Droid X General Discussion
    Last Post: 07-22-2010, 07:59 AM
android google maps navigation auto rotate
android navigation doesn't rotate
android navigation not rotating
google maps navigation does not rotate
google maps navigation not rotating
google maps won't rotate
google maps wont rotate
google navigation doesn't auto rotate
google navigation doesn't rotate
how to make google navigation rotate
