"The process com.google.process.gapps has stopped unexpectedlly, please try again
This is a discussion on "The process com.google.process.gapps has stopped unexpectedlly, please try again within the Droid X Help forums, part of the Droid X Discussion category; "The process com.google.process.gapps has stopped unexpectedly, please try again Can anyone help me with a fix for this. I did a search, but did not ...
Results 1 to 8 of 8
Thread: "The process com.google.process.gapps has stopped unexpectedlly, please try again
    100 Experience Points7 days registered
    salin's Avatar
    17570
    30
    Can anyone help me with a fix for this. I did a search, but did not locate anything.
    Points: 1,813, Level: 25
    Level completed: 13%, Points required for next Level: 87
    demonhawk1313's Avatar
    4828
    NY
    76
    Found this thread over at XDA that was discussing it. Not sure if it will be helpful. Its a little old though.
    com.google.process.gapps - xda-developers
    Also check this one out. A bit newer.
    http://androidforums.com/g1-support/...t-syncing.html
    salin's Avatar
    17570
    30
    You're right, the links are old. Hopefully someone will respond with a little more current solution.........not that the older solution would not work.
    4828
    NY
    76
    Did you remove or rename any apks? Can you access the market?
    salin's Avatar
    17570
    30
    I did remove some apps from the home screen. I just dropped the icon into the trash can.
    I can access the "Market".
    What are you thinking?
    4828
    NY
    76
    I was reading on another site about someone removing one of the main google services from the system folder and it wreaking havoc with other services and causing that error. Aside from a factory reset, I'm at a loss. Hopefully someone else can chime in with a better solution.
    salin's Avatar
    17570
    30
    I was on with a Verizon senior tech support person for over an hour this morning trying to resolve the issue. They tried everything but a hard reset. They said I had a corrupted app. within Google email.
    We got the error message every time an email was sent from gmail. They checked all settings and any known current issues with Google.
    I'm still within my 30 exchange window, so I swapped the phone for an new one as advised by the Verizon support.
    So far, everything seems to be working just fine.
    I'll let you know if it doesn't.
    4828
    NY
    76
    Glad you got it resolved. Hopefully you don't see that anymore.
  1. Replies: 2
    Last Post: 10-03-2010, 10:25 PM
  2. I have begun the 12 step process
    By ProPhotoGA in forum New Member Introductions & Site Assistance
    Last Post: 09-23-2010, 11:19 AM
  3. Gps toggle process
    By iDr0id in forum Off-Topic Discussion
    Last Post: 08-23-2010, 01:26 PM
  4. UID 1001 partial awake process
    Last Post: 08-08-2010, 10:29 PM
  5. Process Manager and Appkiller
    By romanvail in forum Droid X Apps
    Last Post: 07-31-2010, 04:37 PM
com.google.process.location has stopped
process.com.google.process.gapps has stopped
the process com.google.gapps has stopped
the process com.google.process.gapps has stopped
the process com.google.process.gapps has stopped unexpectedly
the process com.google.process.gapps has stopped unexpectedly. please try again
