Lost my stock Droid Widget or Shortcut "Recent Calls"
This is a discussion on Lost my stock Droid Widget or Shortcut "Recent Calls" within the Droid X Help forums, part of the Droid X Discussion category; "Recent Calls" - I had this icon on my Droid X home screen and some how knocked it to another screen. Tried to swipe it ...
Results 1 to 2 of 2
Thread: Lost my stock Droid Widget or Shortcut "Recent Calls"
    Tagger Second Class
    gullenj's Avatar
    19015
    "Recent Calls" - I had this icon on my Droid X home screen and some how knocked it to another screen. Tried to swipe it back over without success, so I put it in the trash can. Went back to home screen and tried to add it. Can't find it anywhere. Not in Motorola, Android widgets, or Shortcuts or Apps. There is a "Recent" folder, but it doesn't provide the same data. Can I retreive this shortcut? Or do I have to do a hard reset?
    Thanks.
    JG
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Hello and welcome to the forums!!
    Long press, from the popup box select shortcut, dialer, recent calls list...this should be what you are looking for...
  1. Replies: 3
    Last Post: 12-12-2010, 01:42 PM
  2. Stock contact "speed dials" on home screen
    By AndroidScott in forum Droid X Help
    Last Post: 12-11-2010, 08:44 PM
  3. Replies: 1
    Last Post: 08-30-2010, 04:10 PM
  4. simple widget to play "droid" sound
    By freshgeardude in forum Droid X Apps
    Last Post: 08-06-2010, 08:05 AM
  5. "Home screen shortcut: Contact" Question
    By gl9east in forum Droid X General Discussion
    Last Post: 08-01-2010, 04:07 PM
Droid x recent calls widget
add recent calls shortcut android
android recent calls shortcut
android recent calls widget
recent call icon droid
recent call widget android
recent calls icon
recent calls widget
recent calls widget android
