My droid x stopped getting emails
This is a discussion on My droid x stopped getting emails within the Droid X Help forums, part of the Droid X Discussion category; For no reason to me, it stopped fetch emails from my yahoo, company, and another email account. I removed Yahoo account and added it back. ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: My droid x stopped getting emails
    MDDC's Avatar
    13739
    61
    I removed Yahoo account and added it back. Stll the same.
    Anybody knows what is wrong?
    Thanks for help!
    Points: 1,282, Level: 19
    Level completed: 82%, Points required for next Level: 18
    Overall activity: 1.3%
    albokay's Avatar
    18203
    78
    Same happened to me. Had to download maildroid.
    MDDC's Avatar
    13739
    61
    albokay, thanks for your information. But this does not seem right. The messaging or messages widgets or applications coming with the droid should work.
    Could be the storage space is full or something else?
    Best.
    Points: 1,419, Level: 21
    Level completed: 19%, Points required for next Level: 81
    Overall activity: 0.6%
    Mark22's Avatar
    17530
    91
    Yep, same problem here. Corporate emails now today just stop coming as well my yahoo account. I can not stop what I am doing and hit refresh to get emails. FWIW: I still have my iphone activated and the same emails go to that exchange account as they should. Having owned the DX for a couple weeks I can honestly say: not real impressed
    Points: 1,373, Level: 20
    Level completed: 73%, Points required for next Level: 27
    BigDaddyNYY's Avatar
    7113
    PA
    116
    11 times
    Sure this isn't much help, but have you tried the power control widget and use that to toggle AutoSync option. I know that there have been a lot of people that have complained about not receiving emails, and using the power control widget has helped to ensure that Autosync was turned on. Fortunately my emails work with the stock messaging tools, I have a Corp, gmail and two hotmail accounts (30 minute fetch) linked to my X, and have not had a problem. I am sure that you have gone through all of your settings, but if you need to compare any please let me know. One thing to check is what battery profile you are using, as one of them turns off background data after a set amount of time, not sure if that also turns off the email sync, but may be worth checking your setting. Also, make sure that you did not enable Sync over Wi-Fi only (unless you want this), as I had done this at one point not reading what I was checking, and had to find this to set phone to retrieve email when not connected to wi-fi.
    Good luck
    Mark22's Avatar
    17530
    91
    Thxs, I will check out the widget u mentioned. BTW: my settings are set as follows:
    data push- checked
    fetch schedule- manual
    sync over wi fi- no
    batt mode- performance
    7113
    PA
    116
    11 times
    For your Yahoo account and any other POP3 accounts, I think you need to set a fetch time otherwise you will have to manually sync to retrieve it (not sure about Yahoo, as they were supposed to come out with a push option on Android), so I would set a time frame for fetch for the POP3 accounts, or have those linked to a Gmail account so that they will work with the Push Option. Under Data Manager, I assume you have Background Data Checked as well as Data Enabled.
    Mark22's Avatar
    17530
    91
    Quote Originally Posted by BigDaddyNYY View Post
    yes, background and data are both checked/enabled. Honestly, my yahoo account is not nearly as important as my corporate exchange and as such I have gone as far as to delete the yahoo account all togther and still not receiving emails automatically to exchange. I also tried the app called touchdown for exhange hoping this would be better and although I seemed to get my emails immediately- it produced other problems. I have called the VZ store and as much as I want to keep the DX- the jury is still out.
    Points: 1,784, Level: 24
    Level completed: 84%, Points required for next Level: 16
    dtsig's Avatar
    17218
    Oregon
    191
    7 times
    Quote Originally Posted by Mark22 View Post
    data push- checked
    sync over wi fi- no
    Mine works quite well .. settings are
    data push- checked
    fetch schedule- 15 minutes
    sync over wi fi- no
    batt mode- night time saver
    HTH
    Points: 5,591, Level: 48
    Level completed: 21%, Points required for next Level: 159
    zoe's Avatar
    9237
    lost angels
    1,429
    33 times
    try the k-9 mail app, it works as expected for me to receive emails that are pushed from my server, and faster than my desktop can get them.
    the customisation options are greater than the default app, and i expect this will work with an exchange server depending on how you configure it, I use linux hosting for my sites so exchange isn't something i can vouch for. there's a free version, and this is what i use, so it can't hurt to give it a shot... yahoo I know has been problematic for some android users, and really pop3 on a phone invites more problems, can you switch it to an imap setting?
  1. Replies: 5
    Last Post: 12-21-2010, 11:09 PM
  2. Droid X- Need Quick Text for Emails - Please Help!
    By Missmymoto in forum Droid X Help
    Last Post: 09-18-2010, 01:26 PM
  3. Gmail email stopped syncing on Droid X with 2.1
    By luckyzu in forum Droid X Help
    Last Post: 08-23-2010, 12:30 PM
  4. notification stopped
    By Sean Wristen in forum Droid X Help
    Last Post: 08-14-2010, 11:55 AM
  5. Replies: 7
    Last Post: 07-16-2010, 07:55 PM
android not getting emails
droid not receiving email
droid stopped receiving email
i stopped getting emails on my droid
my droid stopped receiving emails
not getting email on droid
not getting emails on android
not receiving emails on droid x
why am i not getting emails on my droid
why did my email stop on my droid
