How do I merge my phone contacts into my google contacts.
This is a discussion on How do I merge my phone contacts into my google contacts. within the Droid X Help forums, part of the Droid X Discussion category; When I very fist got my droidx on release day I cleared all of my contacts out of my gmail by accident. They were put ...
Results 1 to 10 of 16
Like Tree2Likes
Thread: How do I merge my phone contacts into my google contacts.
    Points: 1,718, Level: 24
    Level completed: 18%, Points required for next Level: 82
    Overall activity: 2.2%
    Aydos's Avatar
    9970
    94
    When I very fist got my droidx on release day I cleared all of my contacts out of my gmail by accident. They were put in by a blackberry and some 3rd party software and were weird so when I tried to fix it I lost them.
    Anyways. On my Droid X I have all of my contacts under phone contacts and if I display group for google it has like 5 contacts who are saved in my email.
    Is there a way to get all of my phone contacts to my google contacts without manually typing them all in from my gmail?
    Points: 4,788, Level: 44
    joeyjackpot's Avatar
    9452
    1,586
    84 times
    Login to backup assistant online (www.verizonwireless.com/backupassistant) You can download all your contacts as a .csv and then you can upload them to Gmail using an import contacts setting. This must be done on a computer, though.
    It's also good to save the Backup Assistant formatted .csv as a backup for backup assistant (lol) - their servers SUCK!
    Aydos likes this.
    Troubles installing OTA 2.3.340 Update? Click Here
    Aydos's Avatar
    9970
    94
    Thank you. I am noticing problems with there server already. It just loads and loads and loads then tells me that their server did not respond.
    Aydos's Avatar
    9970
    94
    BTW. Is there not a way to make them manually sync ? Or is there a way to only use my google contacts and get rid of the phone contacts without messing anything up?
    It would be nice to be able to add someone to the phone and it appear in my google contacts on gmail and vice versa.
    9452
    1,586
    84 times
    EDIT: looked at my phone. This is a 3 step process.
    1. Contacts press Settings hardkey. Go to More. Settings. Check "Phone Contact," "Google Contact" or Both to decide how new contacts are created *I RECOMMEND BOTH - it will automatically link them and then backup contacts to both Gmail AND backup assistant as BA only recognizes Phone contacts - this will be useful if you ever leave Android*
    2. Go to Accounts>Google Account>Settings - Check "Sync Contacts."
    3. Hard press homescreen, select Power Control widget (not sure if it's Moto or Android widget) and make sure the Sync icon has a green light. If not, press it to enable Sync.
    New contacts will now update to both Backup Assistant and your Gmail account.
    9452
    1,586
    84 times
    Post above updated w/ procedure.
    Points: 1,784, Level: 24
    Level completed: 84%, Points required for next Level: 16
    dtsig's Avatar
    17218
    Oregon
    191
    7 times
    backupassistant only backed up 68 of my 109 contacts <sigh> ... gmail doesn't show any <SIGH>
    9452
    1,586
    84 times
    Backup Assistant will only backup Phone Contacts, never google contacts, facebook, twitter etc.
    Gmail will only backup Google contacts, never Phone contacts, facebook, etc.
    If you want them to mirror each other, you need to get ALL of them one one of the servers, Export to .csv, then Import to the other. Let your phone sync, then link the contacts if it doesn't automatically.
    Lengthy, but you only have to do it once.
    9452
    1,586
    84 times
    Quote Originally Posted by Aydos View Post
    This happens to me. Workaround that has been re-creatable for me: Sign out of MyVerizon, then Sign Back in.
    Reloading backup assistant, reloading the page, or navigating away from backup assistant then clicking it again without logging out of My Verizon then back in will leave you staring at the red & black arrows FOR HOURS - TRUST ME. Signing out and then back in once in the same browser has magically worked a few times for me.
    It also plays nicer with Explorer than Firefox.
    If you have issues getting the scrollbar to work (or even appear), edit any contact and save it. This refreshes the interface.
    Backup assistant also logs you out every 5-10 minutes (even if you're actively using it). so do things in small batches.
    Points: 5,792, Level: 49
    Overall activity: 19.7%
    RedBank's Avatar
    9736
    92
    This is a nice write up. I have learned to simply use google contact for all of my address book needs...much more reliable.
    For example...when I add a new number on my phone...I will always go to my computer and formally add it to my Google contacts.
    As stated already...backup assistant will NOT back up all of what you see (or think) in your phone's contact list. And then every so often...I will export my phone contacts, my gmail contacts, facebook contacts, all contacts. Its four separate files exported to your sd card and then you are good to go.
  1. Replies: 5
    Last Post: 07-13-2013, 01:56 PM
  2. Replies: 6
    Last Post: 10-28-2010, 08:46 AM
  3. Contacts. - Only view MOBLIE phone contacts
    By metmer in forum Droid X General Discussion
    Last Post: 10-22-2010, 12:03 PM
  4. syncing google contacts with phone contacts
    By dogman356 in forum Droid X Help
    Last Post: 10-01-2010, 12:24 PM
  5. Adding Google account to a phone with Contacts
    By shamy in forum Droid X Help
    Last Post: 08-22-2010, 12:54 PM
how do i merge contact with google
how do i merge my contacts on my android
how to merge android contacts with gmail
how to merge contacts from android phone to gmail
how to merge contacts from phone to gmail
how to merge phone contacts with gmail
how to merge phone contacts with google contacts
merging phone contacts with google contacts
