How do I merge my phone contacts into my google contacts.
This is a discussion on How do I merge my phone contacts into my google contacts. within the Droid X Help forums, part of the Droid X Discussion category; Thanks again. I went to the site, saved my contacts as a csv, and imported them to my gmail contacts. I also checked the google ...
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Like Tree2Likes
Thread: How do I merge my phone contacts into my google contacts.
    Points: 1,718, Level: 24
    Level completed: 18%, Points required for next Level: 82
    Overall activity: 2.2%
    Aydos's Avatar
    9970
    94
    Thanks again. I went to the site, saved my contacts as a csv, and imported them to my gmail contacts. I also checked the google box on my phone like you said. So now in theory if I add something on my gmail contacts it should appear on my phone and if I add something on my phone contacts it should show up on my gmail corret.
    Points: 4,788, Level: 44
    joeyjackpot's Avatar
    9452
    1,586
    84 times
    BA will back up all Phone contacts. If you don't know what's a phone contacts, Open Contacts, then click "All Contacts" and select "Phone contacts" or log into Backup Assistant online. Everything there is what BA is backing up.
    @RedBank, you can get your Google and Backup Assistant to mirror each other. Simply export both and then import them to each other. Then check both Google & Phone for New Contacts in Contacts>Settings>More>Settings and all new contacts will go to both. You can even sync your contact's pictures from Facebook to Google using SyncMyPix (but only for users where your phone or syncmypix has linked a Facebook account to a Phone Contact - SyncMyPix can't sync photos for Facebook Only contacts as FBO contacts are read-only... but there might be a way to change this with root. If anyone discovers how to make FB contacts read/write, SyncMyPix will be the solution to updating all contact photos from Facebook except your own.)
    RedBank likes this.
    Troubles installing OTA 2.3.340 Update? Click Here
    9452
    1,586
    84 times
    Quote Originally Posted by Aydos View Post
    This is correct... with Should being the operative word. Let us know if it doesnt work and we can troubleshoot that process... lol
    Aydos's Avatar
    9970
    94
    Everything is working exactly how I wanted it to. Thank you.
    Points: 5,792, Level: 49
    Overall activity: 19.7%
    RedBank's Avatar
    9736
    92
    Quote Originally Posted by joeyjackpot View Post
    for the love of all that is holy and sacred...i just imported the 4 vCards i just created today. see...i wasnt even going to chime in on this post either...and i just learned an Android life-changing event.
    thanks joey!
    9452
    1,586
    84 times
    you're welcome!
  1. Replies: 5
    Last Post: 07-13-2013, 01:56 PM
  2. Replies: 6
    Last Post: 10-28-2010, 08:46 AM
  3. Contacts. - Only view MOBLIE phone contacts
    By metmer in forum Droid X General Discussion
    Last Post: 10-22-2010, 12:03 PM
  4. syncing google contacts with phone contacts
    By dogman356 in forum Droid X Help
    Last Post: 10-01-2010, 12:24 PM
  5. Adding Google account to a phone with Contacts
    By shamy in forum Droid X Help
    Last Post: 08-22-2010, 12:54 PM
how do i merge contact with google
how do i merge my contacts on my android
how to merge android contacts with gmail
how to merge contacts from android phone to gmail
how to merge contacts from phone to gmail
how to merge phone contacts with gmail
how to merge phone contacts with google contacts
merging phone contacts with google contacts
