How can I remove duplicate contacts after sync?
This is a discussion on How can I remove duplicate contacts after sync? within the Droid X Help forums, part of the Droid X Discussion category; I just synced my contacts using DejaOffice and I now have duplicates of most, but not all contacts. Anyone know how to correct this....
Results 1 to 10 of 10
Thread: How can I remove duplicate contacts after sync?
    100 Experience Points7 days registered
    salin's Avatar
    17570
    30
    X Pursuant Achievements:
    z06mike's Avatar
    1491
    558
    23 times
    Are the contacts you want in your google account?
    salin's Avatar
    17570
    30
    I don't know.........how can I tell? This is a new phone for me, coming over from a Blackberry. Wouldn't there automatically be a Google account after the contacts were downloaded through Verizon.
    I don't use gmail as my email client so I don't have a contact list on my computer if that answers your question.
    Points: 1,649, Level: 23
    Level completed: 49%, Points required for next Level: 51
    250 Experience Points31 days registered100 Experience PointsCreated Album pictures7 days registered
    l_n's Avatar
    13051
    Knoxhell, TN
    77
    11 times
    Log into http://www.google.com/contacts . There's an option to merge duplicates. All changed made in the web interface will automatically sync to your phone.
    salin's Avatar
    17570
    30
    Thanks for the link. I don't have any duplicates on the gmail contact list.
    Also, I have a few contacts that are not updating during sync because there not in my droid contacts list. There not on my gmail contact list either, but there still listed in my email client. I use "Intellect" from Time & Chaos.
    Any thoughts?
    salin's Avatar
    17570
    30
    Resolved.
    Called Verizon and they said that Backup Assistant is the problem. You can not have BA running. We did a complete reset back to original setting and performed the sync.
    Worked great. All contact and calendar are as they should be.
    z06mike's Avatar
    1491
    558
    23 times
    What do you mean you can't have Backup Assistant running?
    salin's Avatar
    17570
    30
    That's what a senior tech told me. It somehow/sometimes conflicts with the gmail account.
    ChrisSmithWebGuy's Avatar
    25895
    Seattle, WA
    I'm very often find duplicate contacts. I have long wondered how to solve this problem, and Scrubly Duplicate Remover came to my aid. This really works well for me. This tool is really useful and indeed an effective one.
    This is frustrating, first most of my contacts were duped. Found the problem being one from Gmail, one from Verizon BA Assistant. Did not want to totally reset phone. Went online, deleted everything in BA Assistant. Took care of most but not all. Then opened dupes on the Droid, his edit and it showed to where it was sync'd. Deleted them one at a time. Now my Dejaoffice contacts are duplicated! I use Outlook at home and don't want to put everything into Gmail, plus Office has notes, etc. Someone has to come up with a better app to sync Outlook to Droid.
  1. How to Eliminate Duplicate Contacts
    By calpalmer in forum Droid X General Discussion
    Last Post: 03-04-2013, 01:31 PM
  2. Unable to remove Corporate Sync mail account
    By jbelew in forum Droid X Help
    Last Post: 01-25-2011, 03:59 PM
  3. Replies: 0
    Last Post: 10-07-2010, 09:57 PM
  4. sync'ing contacts?
    By medicscott in forum Droid X Help
    Last Post: 08-06-2010, 01:08 AM
  5. Contacts don't sync
    By airboss1998 in forum Droid X Help
    Last Post: 08-03-2010, 11:41 PM
deja office duplicate contacts
deja office gmail
dejaoffice duplicate contacts
dejaoffice duplicates
delete duplicate contacts droid razr
delete multiple linkedin contacts on droid x
how to delete all contacts in dejaoffice
remove duplicate contacts android
remove duplicate contacts on droid x
why do i have duplicated contacts in my android phone
