Several Apps stuck on "Installing"
This is a discussion on Several Apps stuck on "Installing" within the Droid X Help forums, part of the Droid X Discussion category; I have several apps stuck on "installing" (5 total.) The apps are Tethering, Instant Heart Rate, Bamboo Forest Live Wallpaper, Foursquare, and Grooveshark. I even ...
Results 1 to 10 of 10
Thread: Several Apps stuck on "Installing"
    Points: 1,502, Level: 22
    Level completed: 2%, Points required for next Level: 98
    100 Experience PointsTagger Second Class3 months registered31 days registered7 days registered
    chipthamac's Avatar
    3606
    7
    I even went into manage apps, and force stopped them, then uninstalled them. still when I open market, and go to downloads or search for one of those apps, they show a progress bar (with no progress) and state that they are installing.
    I have tried rebooting. I have tried pulling the battery and leaving it out for 10 minutes. I have tried searching. Any help on this would be greatly appreciated.
    Thanks.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    It could be a 3G issue - do you have access to wifi? Also, try them one at time to see if you can get past whichever one might be hanging up...but my guess is it is the network itself...
    chipthamac's Avatar
    3606
    7
    Yes, I have in fact tried wifi. I am at the point where I can not try them one at a time, there is the list of the five of them that are just sitting there stuck on installing. They have been in this state for about two weeks, even though I have even went into the application manager and uninstalled them.
    hchsim's Avatar
    8488
    41
    I've had the same problem occasionally with installing/updating apps, where the app(s) would get stuck. I've always been able (so far, keep my fingers crossed) to be able to close Market (use the "back" button) and restart and it usually works the second time around. Usually, I am on wifi when updating/installing apps.
    20,509
    885 times
    Clearing data / cache might also help....phone settings - applications - manage applications - open app, tap on clear data, clear cache...
    Points: 1,463, Level: 21
    maxpower's Avatar
    11440
    Ohio
    137
    I had this same problem. I don't remember how I fixed it though.
    It is very annoying when it happens.
    chipthamac's Avatar
    3606
    7
    I have deleted the app already, as stated above, now I can't install it again, because when I go to install it, it says it's "installing" This is very aggravating, because I use/pay for grooveshark and it is one of the apps stuck "installing" is there really no easy fix for this?
    Points: 1,427, Level: 21
    Level completed: 27%, Points required for next Level: 73
    FromBBtoDroid's Avatar
    15867
    State College
    27
    Quote Originally Posted by chipthamac View Post
    No, not deleting the app. You want to go in to manage applications and clear cache and data from the market. I had this problem a few times and that worked every time.
    20,509
    885 times
    Have you attempted to force close the Market to see if that will help to reset any connections?
    chipthamac's Avatar
    3606
    7
    Smile
    Quote Originally Posted by FromBBtoDroid View Post
    Thanks! I thought you were saying clear data/cache for the apps that were stuck installing. I went to manage applications > market, then cleared cache and deleted data, then just for extra measure I forced closed the the post below yours suggested as well. I then went into the market and it asked me to accept the EULA again, then all my apps that were stuck "installing" were now unstuck.
    Thanks for the great help guys/gals.
    See ya around, and hope this thread helps someone else.
  1. Stuck at "M" after system restore with ROM mananger
    By Beranimus in forum Droid X Hacks
    Last Post: 03-07-2011, 06:25 PM
  2. Replies: 13
    Last Post: 12-25-2010, 01:01 PM
  3. Replies: 1
    Last Post: 09-16-2010, 10:45 AM
  4. Gmail stuck in "Sending"
    By jtdiddy in forum Droid X General Discussion
    Last Post: 09-03-2010, 08:31 PM
  5. "SweetDreams" vs. "Timeriffic" vs. "Locale" vs. ????
    By AndroidScott in forum Droid X Apps
    Last Post: 09-03-2010, 06:32 AM
app install stuck on installing
app stuck installing
apps stuck on installing
facebook app stuck installing
facebook app stuck on installing
facebook iphone app stuck installing
facebook stuck on installing
iphone app stuck on installing
iphone apps stuck on installing
