I did a factory reset on my phone. After doing it, when using the google navigation, rather than getting turn by turn directions, I now get chimes for the prompts and can't find where to change. Any ideas?
This is a discussion on Restored phone to factory settings, lost turn by turn directions within the Droid X Help forums, part of the Droid X Discussion category; I did a factory reset on my phone. After doing it, when using the google navigation, rather than getting turn by turn directions, I now ...
it may be the settings in the maps... make sure you have the google navigator installed
Navigator is installed. That is the program I am using
Have you checked the Market to see if your Google Maps has an update available? Try that.
If it doesn't work, I would uninstall the app, reboot your phone (unnecessary, theoretically, but I do it anyway), and download and install Google Maps off the market again.
