Video Player?
This is a discussion on Video Player? within the Droid X Help forums, part of the Droid X Discussion category; I put some *.avi movies onto my SD card for the times when things are boring. However, the Android Gallery App takes forever to load ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Video Player?
    Points: 968, Level: 16
    Jim_KT's Avatar
    16425
    12
    Video Player?
    I put some *.avi movies onto my SD card for the times when things are boring. However, the Android Gallery App takes forever to load them. In fact, I've never been able to get one to load. What media players are you folks using for videos?
    Points: 23,189, Level: 93
    Level completed: 84%, Points required for next Level: 161
    250 Experience PointsCreated Album pictures100 Experience PointsThree FriendsTagger Second Class
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    RockPlayer and arcMedia are what I have. There is also VPlayer Alpha, but it doesn't work on all videos because the DX is purported not to be compatible with the app. Hope that helps!
    The Droid was BORN great
    "Be not afraid of greatness. Some are born great, some achieve greatness, and some have greatness thrust upon them..." -William Shakespeare
    3 months registeredCreated Album pictures31 days registered100 Experience Points7 days registered
    dan266's Avatar
    446
    Ft. Lauderdale, Fl.
    20
    My videos all play perfect, Convert them to mp4 and try again. There are several converters free on the internet. I use Format Factory.
    Pain is your friend,
    If your in pain,
    Your still alive!
    Jim_KT's Avatar
    16425
    12
    Hmmmmm.
    Rock Player, and arcMedia play the videos. Now, I just need to make it so that the videos are not previewed under the Android Gallery.
    Jim_KT's Avatar
    16425
    12
    I'm giving Format Factory a try. Perhaps my phone is just grumpy with AVIs.
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    Quote Originally Posted by Jim_KT View Post
    Hmmmmm.
    Create a folder on your SD card using an app such as Astro file manager, or eStrongs, with a "." at the beginning of the file name (example: .videos) and put the videos in there. For arcMedia, you will need to use the file manager app to open the video file to watch it. Or, with RockPlayer, just launch the app, go to folder, and then play it. The videos will still show up, but not play, in the Gallery, so you will need to refresh it. To do this, either restart the phone, or download the app called "SDrescan" by Benjamin Rosseaux (Click here for the app details on AppBrain)
    Let me know if you have any issues, and I, or others, will be happy to assist!
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    NOOOO!!!! It most likely won't solve anything. Android is very picky with the codecs and bit/frame rate used in the videos; and if they aren't just right, then they won't play. Jive my post above a try first. I have had lots of issues with the Android Gallery, and have worked around just about all of them, and can probably get you through it without turning to a factory recovery...
    Jim_KT's Avatar
    16425
    12
    Thanks for the advice, and help. I appreciate it.
    I gave the renaming a try via ASTRO file manager, etc..
    However, for some reason my Android Gallery certainly did not like those AVIs. I converted them to MP4s and all is good.
    Points: 2,454, Level: 30
    Level completed: 3%, Points required for next Level: 146
    Overall activity: 0.6%
    B.E.McAllister's Avatar
    15405
    91
    Thank you so much for the renaming of my tv show folder. i hated having them in my gallery. Much Thanks!
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    No prob. if you ever want something hidden, just put them into a floder with a "." berfore the name. To Android, a "." is equivalent to the hidden foler setting in Windows. Just FYI. I haven't tried it on the files themselves, yet. So I don't know if the same applies to the files themselves, while still being able to open them. But I don't see why not.
  1. Possibly the only video player you will ever need...
    By hollywood in forum Droid X Apps
    Last Post: 02-04-2011, 01:53 PM
  2. Replies: 0
    Last Post: 09-29-2010, 07:56 AM
  3. What video player plays .mkv
    By EdgeKrusher187 in forum Droid X General Discussion
    Last Post: 09-24-2010, 04:25 AM
  4. Video Player playing audio in Spanish???
    By s2k_848 in forum Droid X Help
    Last Post: 08-28-2010, 12:14 AM
  5. Change default video player?
    By patsonrt1 in forum Droid X Audio / Video
    Last Post: 08-08-2010, 07:48 AM
android video player taking forever to load
arc media player not in store
arcmedia default
droid video player not working
droid x default video player
droid x video player
droid x video player not working
how to make vplayer default player on droid
x .videos
x video player
