Slow to load websites and fails to load youtube videos and sometimes phone freezes
This is a discussion on Slow to load websites and fails to load youtube videos and sometimes phone freezes within the Droid X Help forums, part of the Droid X Discussion category; I bought my droid x about a month ago. It has updated to android 2.2. I have looked through the forums and not found anything ...
Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By droider4life
  • 1 Post By Martin030908
  • 1 Post By CBGOODMAN200A
Thread: Slow to load websites and fails to load youtube videos and sometimes phone freezes
    3 months registered100 Experience Points31 days registered7 days registeredTagger Second Class
    smiledotcom's Avatar
    17528
    southeastern u.s.
    9
    Angry Slow to load websites and fails to load youtube videos and sometimes phone freezes
    I bought my droid x about a month ago. It has updated to android 2.2. I have looked through the forums and not found anything that helps me. My phone has been slow to load anything that has to do with the internet, and most of the time it will not even play a youtube video. My dinosaur of a computer that has windows XP and only accesses the internet through dialup can load webpages and youtube videos faster than my droid x. Sometimes if the internet is slow I press the 'home' button and it freezes my phone. I will then have to remove the battery because thats the only way to turn it off when it freezes. I have alreadt tried toggling airplane mode, removing the battery, clearing caches, and force stop to background applications. I DO NOT WANT TO ROOT MY PHONE, but I do want a better droidx-internet experience. I have only downloaded a handful of apps so far, hopefully they are not the problem, but it wouldnt hurt to know if one of them was the culprit. Any help is appreciated.
    boost192's Avatar
    8437
    95
    Are you on 3g or wifi? and how many bars on 3g if so?
    17528
    southeastern u.s.
    9
    3G with 3-4 bars.
    I forgot to list my downloaded apps
    Barcode scanner
    Google earth
    Pandora radio
    Emergency medical Spanish
    Google skymapskymap
    Antivirus
    Facebook
    Hypnotic spiral
    Jewels
    Adobe flash 10.1
    Mobile banking
    Gmail
    Mobile recovery
    My verizon
    Retro camera
    Ringdroid
    Google streetview
    Okay... more than a handful. Could any of these cause problems?
    trainedgymrat's Avatar
    8849
    38
    I don't see any apps that should be affecting your phone from that list. My list is ten times longer. Have you tried verizon tech support? Do a battery pull, if that doesn't help goto your browser and clear history and cache. Last resort in my opinion is to do a factory reset? Lot of smart people in these forums wait for some more insight. Good luck
    8849
    38
    Also for youtube make sure you update to the newest version if you haven't done so.
    31 days registeredTagger Second Class250 Experience Points7 days registered100 Experience Points
    droider4life's Avatar
    16734
    smalltown U.S.A.
    125
    Quote Originally Posted by smiledotcom View Post
    3G with 3-4 bars.
    Barcode scanner
    Google earth
    Pandora radio
    Google skymapskymap
    Antivirus
    Facebook
    Hypnotic spiral
    Jewels
    Adobe flash 10.1
    Mobile banking
    Gmail
    Mobile recovery
    My verizon
    Retro camera
    Ringdroid
    Google streetview
    I would try deleting antivirus. I have read it will ruin your web experience and it isn't needed for android anyways, as there is not any known viruses yet.
    smiledotcom likes this.
    Tagger Second Class7 days registered250 Experience PointsThree Friends100 Experience Points
    Martin030908's Avatar
    18
    1,089
    46 times
    Delete the anti-virus.... or at the very least... disable the auto protect. All it's doing is running and wasting resources... there's no 'viruses' in Android (yet) for it to catch.
    Malware has shown up in Android, but that has to do with apps and the permissions they're given.
    Points: 2,300, Level: 28
    Level completed: 50%, Points required for next Level: 150
    500 Experience Points250 Experience Points7 days registered100 Experience PointsCreated Album pictures
    CBGOODMAN200A's Avatar
    5227
    Rochester, NY
    196
    I sometimes have to clear the cache. Not sure why, but it works.
    17528
    southeastern u.s.
    9
    Ive cleared the cache many, many times, but I will give 'disabling antivirus' a try, to see if there is any improvement.
    17528
    southeastern u.s.
    9
    I went to manage applications in the phone settings menu and did a force stop. INSTANT improvement. Thank you so much.
  1. Youtube Upload Fails
    By baniels in forum Droid X Help
    Last Post: 05-31-2012, 03:17 PM
  2. How to load a backup
    By Droid-Xer in forum Hacking Help
    Last Post: 05-17-2011, 08:56 AM
  3. Why do you Root or load a custom ROM?
    By UnlikelySalsero in forum Droid X General Discussion
    Last Post: 12-23-2010, 10:18 PM
  4. stuck on load screen
    By elemeno89 in forum Droid X Rescue Squad
    Last Post: 10-27-2010, 10:49 AM
  5. YouTube slow to load...
    By hollywood in forum Droid X Help
    Last Post: 08-26-2010, 11:53 PM
android slow video loading
my android loads videos slow
videos load slow on android
videos loading slow on android
why do videos load slow on my android
why do videos load slow on my phone
why does my phone load videos slow
why does youtube load so slow on my android
why is my phone loading videos so slow
why is youtube so slow on my phone
