Android Market
This is a discussion on Android Market within the Droid X Help forums, part of the Droid X Discussion category; *mod edit* Market is down. It's not device, ROM, or root vs non-root specific. DF is seeing a number of people reporting the same. It's ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
Thread: Android Market
    skullxbones's Avatar
    12980
    Market app stuck on installing
    *mod edit*
    DF is seeing a number of people reporting the same. It's all over Twitter as well.
    Be patient... nothing we can do, it's on Google's end.
    -original post below-
    I had the free version of soundhound installed, then deleted it (I think). Now when ever I openup market, it's always trying to install it, but the download never starts.
    I deleted the soundhound folders hoping that would let it download but it didn't help.
    Is there any way to remove apps from the market download que?
    31 days registered250 Experience Points7 days registered100 Experience PointsTagger Second Class
    dplsc01's Avatar
    241
    Indianapolis
    231
    21 times
    Quote Originally Posted by skullxbones View Post
    What you have to do is open up the market info page for soundhound cancel download and select install again. Once installed you can delete it permanently, other than that anytime that the app has a update the market will try to install when nothing is there, you can't just delete an app you have to uninstall it as well to make sure it doesn't try to update "nothing"
    midwaymonster's Avatar
    14229
    Chicago Land
    194
    Marketplace jacked up today?
    Neither my phone or my friends can download from marketplace right now. Downloads just sit at "installing" then eventually go to "download unseccessful".
    What gives? Anyone else getting this?
    ambulance dude's Avatar
    5769
    Texarkana AR
    242
    What are you trying to install?
    Sent from my Droid X in an Ambulance using Tapatalk.
    Never do anything you have to explain to the Paramedics!
    When seconds count......We are minutes away.
    14229
    Chicago Land
    194
    Quote Originally Posted by ambulance dude View Post
    I tried several apps....two different phones....scratch that....three different phones now. None of them are downloading successfully.
    12980
    That was the first thing I tried. But when I go to the soundhound info page, there is no option to delete or cancel where the buttons would normally be. Instead the button at the bottom is grayed out and says "installing...". It's like it is trying to start the install but is stuck and gives me no other options.
    When I deleted the app originally, I did it through the App Manager and everything seemed to go smoothly. After I discovered the stuck install, I used a file app to see if there was any left over files or directory from the original install, which there was, so I deleted the file folders to see if it would allow the install to continue or at least stop it.
    Gixxer's Avatar
    2366
    NY
    64
    Yeah. I'm having problems too. My apps won't update nor can I download new apps.
    5769
    Texarkana AR
    242
    Ok just tried it, and I too can not download anything.
    Points: 1,681, Level: 23
    Level completed: 81%, Points required for next Level: 19
    two250's Avatar
    10880
    Santa Clarita, SoCal
    177
    25 times
    There is a problem with the market right now. No apps are downloading, this is probably your issue...
    Samsung Galaxy Nexus - AOKP Milestone 2-Imoseyon LeanKernel v1.5.0
    HTC Thunderbolt - Liquid Gingerbread 3.0-Imoseyon 5.1.0 AOSP Kernel
    Motorola Droid X-Liberty 3 v2.0
    Motorola Xoom - Tiamat 2.2.2-Tiamat 2.6.36.4 Kernel
    Points: 985, Level: 16
    Level completed: 85%, Points required for next Level: 15
    Overall activity: 0.0%
    rickkane's Avatar
    14380
    73
    Question market not working? ?
    Is the market pausing downloads for anyone else or is it just me?
  1. LiveProfile Beta now available in the Android Market
    By LiveProfile in forum Droid X Apps
    Last Post: 10-28-2010, 07:16 PM
  2. android market help after system update.
    By runten in forum Droid X Help
    Last Post: 10-25-2010, 11:40 AM
  3. Question about Android Market
    By BradB in forum Droid X General Discussion
    Last Post: 09-29-2010, 07:53 PM
  4. Android Market and Screen Question.
    By swantzilla in forum Droid X General Discussion
    Last Post: 09-21-2010, 05:59 PM
  5. DROID X - Android Market
    Last Post: 07-15-2010, 02:10 AM
android market reinstall
droid x marketplace not working
how do i reinstall marketplace for droid x
how to reinstall android market
how to remove soundhound for android
reinstall android marketplace
soundhound android wont update
soundhound stuck
uninstall sound hound
