Change Swype Dictionary
This is a discussion on Change Swype Dictionary within the Droid X Help forums, part of the Droid X Discussion category; How does one change the swipe words offered when something is misspelled? Really sux when using numerals. First thing I did was set up phone ...
  • 1 Post By Usquanigo
Thread: Change Swype Dictionary
    wurk_truk's Avatar
    11686
    9
    Question Change Swype Dictionary
    How does one change the swipe words offered when something is misspelled? Really sux when using numerals. First thing I did was set up phone and now THAT 10 digit number is first up, when all I wish to type is '3'., etc...
    Regular phone dictionary adds words but doesn't alter predictive word choices. Help?
    Points: 2,581, Level: 30
    Level completed: 88%, Points required for next Level: 19
    Usquanigo's Avatar
    10513
    347
    8 times
    Teaching Swype a new word is as simple as tapping it in a letter at a time. After that, it should know it. Sometimes you do have to be a little more precise in your pattern as well, because sometimes I see it bring up options, then others it knows exactly what I wanted, for the same given word.
    As for removing... tap the word out, highlight it, then tap the Swype key. That should be that.
    wurk_truk likes this.
    Nextel i1000+ -> Motorola Razr V3 -> Droid X
    31 days registered250 Experience Points7 days registered100 Experience PointsTagger Second Class
    dplsc01's Avatar
    241
    Indianapolis
    231
    21 times
    Also if you find that you are using a lot of words that swype doesn't recognize, there is an app called SMS to Swype, that basically takes everything you say in your text and adds them to the swype dictionary. Its pretty cool because a lot of the work jargon I use and person jargon and slang is now available through swype. even my email addresses are available up until the @domainname but if i type in letter for letter if recognizes the whole thing after three letters.
    Here is the appbrain link SMS to Swype - Android app on AppBrain
    wurk_truk's Avatar
    11686
    9
    Can't seem to be able to remove "7-eleven"; 76ers, etc.
  1. Highlight a word and add to dictionary
    By rjmlakota in forum Droid X Help
    Last Post: 10-20-2010, 09:37 AM
  2. Texting! Swype or No Swype!
    By Synyster in forum Droid X General Discussion
    Last Post: 09-08-2010, 09:28 PM
  3. Adding Words to Custom Dictionary
    By gustofusion in forum Droid X General Discussion
    Last Post: 08-28-2010, 10:44 AM
  4. Swype for dx?
    By Travis873o in forum Droid X Apps
    Last Post: 08-27-2010, 03:03 PM
  5. Change swype keyboard colors/skins?
    Last Post: 07-28-2010, 02:51 PM
Edit swype dictionary
change swype dictionary
edit swype dictionary droid x
how to teach swype new words
swype dictionary
swype dictionary edit
swype dictionary sucks
swype ukraine dictionary
swype ukrainian dictionary
