Transferring iTunes music from an iMac to my Droid X
This is a discussion on Transferring iTunes music from an iMac to my Droid X within the Droid X Help forums, part of the Droid X Discussion category; I am having trouble. My iMac won't recognize my Droid X. When I plus it in I get the following message: The disk you inserted ...
Results 1 to 10 of 18
Thread: Transferring iTunes music from an iMac to my Droid X
    PAISANI286's Avatar
    767
    Brooklyn NY
    The disk you inserted was not readable by this computer.
    with buttons to either ignore or eject.
    Any tips on how to get music on without a card reader?
    nindoja's Avatar
    1245
    13
    Look into Double Twist, that software will sync your iTunes library to your android phone.
    I've yet to try it on the DroidX, but I don't see why it wouldn't work.
    Your first Group250 Experience PointsRecommendation Second ClassThree Friends100 Experience Points
    titans's Avatar
    52
    Why do you want to know?
    240
    14 times
    If that doesn't work theres also iSyncr
    Points: 1,560, Level: 22
    Level completed: 60%, Points required for next Level: 40
    Seven71ne's Avatar
    34
    70
    Imho i can't stand doubletwist because sometimes it doubles the music, or it reads it wrong and will name the songs funny. Don't get me wrong, if i never used itunes id love it, but im sticking with using itunes. Look up itunes agent. Im not quite sure about the program on a mac, but on windows it works flawlessly.
    And on the plus side, its free!
    Sent from my DROIDX
    Cell Phone History:
    (Currently)Droid X - Samsung Omnia i910 - LG Venus - LG Chocolate 1 - Samsung - Flip/Dumbphones(2)
    Points: 1,294, Level: 19
    Level completed: 94%, Points required for next Level: 6
    fightingdevil's Avatar
    317
    6
    For my iMac, I use ITuneMyWalkman. Works pretty well. Well, that is when I can mount my X to the iMac. Ugh...
    zenkyto's Avatar
    1207
    Oklahoma
    21
    Quote Originally Posted by titans View Post
    iSyncr works pretty well, but with the free version you're only able to transfer 20 songs or less
    When you plug it in you need to pull down the notification bar and touch usb connection. Then select USB mass storage mode. I have a macbook pro and it works fine. You can go into the itunes music library, not itunes itself, and drag and drop to the music folder on the droid x. Once you select USB mass storage, you may have to unplug and plug in again for it to show up on the desktop.
    Kate31 likes this.
    RubiJK's Avatar
    1271
    12
    How do you find the music in the library? I am relatively new to my macbook pro... If I look under places I see my name/hardrive... inside that I see libraries which has garage band and itunes... That it??
    edit: nevermind, I found all the folders with the songs... Thanks!
    PAISANI286's Avatar
    767
    Brooklyn NY
    Thanks! Problem solved! I don't want my entire library, just a few albums to get me through. Seems The USB mass storage mode was the key to it. You were right on the money loehrs65! Kudos to you!
    The people at Double Twist said that it only works with 10.5 or higher. If you're running an OX less than that, like me, I'm not sure what to do. Can I just use a card reader and move the tunes that way?
  1. Droid X Sync with iMac
    By ckirkpatrick13 in forum Droid X General Discussion
    Last Post: 12-18-2010, 02:10 PM
  2. Help Transferring Itunes Music to Droid X
    By obert272 in forum Droid X Help
    Last Post: 10-11-2010, 02:31 PM
  3. Droid X Sync with iMac
    By ckirkpatrick13 in forum Droid X Help
    Last Post: 09-13-2010, 09:27 PM
  4. What to do about itunes?
    By Champin4 in forum Droid X General Discussion
    Last Post: 07-22-2010, 06:04 PM
  5. DROID - Transfer & Use Music
    Last Post: 07-15-2010, 12:44 AM
how do i export music fr a mac to my droid
how do i put music from my imac to my android phone
how to download music from imac to android
how to transfer music from imac to android
imac itunes to android
imac to andoid phone music
transfer music from imac to android phone
transfer music from imac to droid
