Car Charger Can't Keep Up with Nav
This is a discussion on Car Charger Can't Keep Up with Nav within the Droid X Help forums, part of the Droid X Discussion category; I use the stock verizon car charger. When using Nav I noticed my battery was discharging even though it was plugged into car charger. This ...
Results 1 to 10 of 12
Thread: Car Charger Can't Keep Up with Nav
    Points: 4,505, Level: 42
    Level completed: 78%, Points required for next Level: 45
    Overall activity: 0.8%
    Cigator's Avatar
    1346
    240
    I use the stock verizon car charger. When using Nav I noticed my battery was discharging even though it was plugged into car charger. This would leave me with a near dead battery on any kind of road trip. Is there a setting to alleviate this? Is there a higher capacity car charger that would stop this from happening?
    Points: 146,349, Level: 100
    Overall activity: 71.4%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    This is a known problem. The nav uses battery quicker than the car charger can keep up with. If you are gonna be using nav alot it might not be a bad idea to buy an extended battery and always keep a fully charged spare with you.
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    As an alternative I let my DX go dormant on long stretches of freeway for this very reason. This allows the charger to catch up.
    Cigator's Avatar
    1346
    240
    Quote Originally Posted by Garemlin View Post
    If this is known, is it being addressed in an update?
    Points: 9,280, Level: 64
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    Is this with the car charger only? In my old car my 12V power in the front didn't work and my charger cord was too short to reach the back plug. So I used a wall charger plugged into an AC converter in the back and it worked well but I never tried GPS for long stretches.
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    The AC charger is probably more than enough to keep up with the GPS since it charges much faster than the car adapter.
    Quote Originally Posted by ryant35 View Post
    Points: 6,551, Level: 53
    Level completed: 1%, Points required for next Level: 199
    B360155's Avatar
    217
    North Richland Hills, TX
    389
    32 times
    I actually gain power using the car charger and the stock car dock when running Nav to the tune of 10% every 1/2 hour to an hour. In other threads, I've read that if the battery reaches a certain temperature, it will stop charging until it drops back down to a lower temperature. I have my unit mounted high on my windshield so that the sun isn't beating down on it directly and that seems to work. You might try that or else I've seen other people's posts that say they mount it close to an air conditioning vent and blow cold air on it when using the Nav so the battery doesn't overheat.
    Points: 1,932, Level: 26
    Level completed: 32%, Points required for next Level: 68
    UnlikelySalsero's Avatar
    3437
    241
    32 times
    Quote Originally Posted by B360155 View Post
    I actually gain power using the car charger and the stock car dock when running Nav to the tune of 10% every 1/2 hour to an hour. In other threads, I've read that if the battery reaches a certain temperature, it will stop charging until it drops back down to a lower temperature. <snip>
    Mine also slowly gains battery charge while running Nav in car. Phone sits in cup holder between seats, out of direct sun. I use third party charger from Best Buy. (Razorback?? Razerfish?? Razer... , Not in car right now so can't check brand.)
    I suspect heat theory is correct, but I never tested it myself.
    Let us know if your unit is in sun when charging.
    Don Baarns
    Points: 1,547, Level: 22
    Level completed: 47%, Points required for next Level: 53
    Overall activity: 0.0%
    mbern1008's Avatar
    1377
    122
    The charger as long as it is an official one that is powerful enough to charge the X properly 950ma or more should be fine to charge the battery while using NAV. The problem that comes into play is when the phone overheats to a temp of about 115 degrees or higher and the phone will no longer accept a charge until it cools back down
    Points: 2,657, Level: 31
    Level completed: 38%, Points required for next Level: 93
    Overall activity: 1.7%
    iresq's Avatar
    4885
    250
    I had issues when I used a windshield mount. I know use a vent mount (radio shack) w/Motorola power cord. It will charge. I have more issues with the nav app freezing, but that's another story.
  1. Droid X Battery Charger (not phone charger)
    Last Post: 05-09-2011, 07:45 AM
  2. car charger
    By Cjtice in forum Droid X Accessories
    Last Post: 09-11-2010, 10:19 AM
  3. droid x charger vs blackberry charger
    By rubi22 in forum Droid X Help
    Last Post: 08-16-2010, 09:19 AM
  4. VZW Charger
    By yurdle in forum Off-Topic Discussion
    Last Post: 08-05-2010, 09:53 AM
  5. Car Charger question
    By supahrob in forum Droid X General Discussion
    Last Post: 07-11-2010, 09:53 AM
car charger cant keep up with lte
droid x discharging when plugged into car charger
radio shackdroid x car charger
