Folder issues: Created Folder, added widgets. Now when i move them they delete
This is a discussion on Folder issues: Created Folder, added widgets. Now when i move them they delete within the Droid X Help forums, part of the Droid X Discussion category; I created a folder to put all the apps that i downloaded into that folder. I then go to a different screen and try to ...
Results 1 to 2 of 2
Thread: Folder issues: Created Folder, added widgets. Now when i move them they delete
    Points: 1,062, Level: 17
    Level completed: 62%, Points required for next Level: 38
    Overall activity: 0.6%
    dangerous's Avatar
    85
    27
    I then go to a different screen and try to add a widget and it will delete and not paste to the screen.
    If i try to move a widget it will delete from the screen.
    I then reboot phone and i can added widgets to the screens and move them.
    If i reopen the folder i created then close it and go to a different screen, it will delete widgets if i try to add or move them.
    Edit
    If i delete the folder (with all my widgets in the folder) it will work fine.
    dangerous's Avatar
    85
    27
    Yep. here is the fix
    https://supportforums.motorola.com/t...art=0&tstart=0
    Edit..
    Sarcastic fix. that is. Reboot your phone
  1. Replies: 5
    Last Post: 07-20-2010, 11:29 PM
  2. explore / copy / move to SD card in the phone?
    By NY_ROCKER in forum Droid X Help
    Last Post: 07-17-2010, 09:14 AM
  3. No DCIM folder???
    Last Post: 07-16-2010, 12:30 AM
  4. added facebook - now there in my contacts eh?
    By silent1643 in forum Droid X Help
    Last Post: 07-15-2010, 08:41 PM
  5. Found this In My Email Folder This Morning, How About You?
    By JimMariner in forum Droid X General Discussion
    Last Post: 07-15-2010, 10:23 AM
add widget to folder
delet a folder fro a driod
droid widgets in folders
droid x folder
droid x folders
droid x vault folder tempupload
how to move folders on acer tablet
how to move widgets to a folder
move widgets to folder
widget folder android
