If there any way to auto enable GPS/Bluetooth when docked?
This is a discussion on If there any way to auto enable GPS/Bluetooth when docked? within the Droid X Hacks forums, part of the Droid X Development category; I would like my bluetooth and Gps to auto enable when I put my DX in the car docking station. any ideas?...
Results 1 to 10 of 10
Thread: If there any way to auto enable GPS/Bluetooth when docked?
    Points: 14,589, Level: 78
    Level completed: 35%, Points required for next Level: 261
    Overall activity: 1.4%
    7 days registeredThree Friends100 Experience PointsYour first GroupCreated Album pictures
    Community Award
    AdamTomaino's Avatar
    434
    Pittsburgh, Pa
    678
    30 times
    jmiller148's Avatar
    3461
    72
    Try "Setting Profiles" in the market.
    Sent via Droid X- Tapatalk
    Points: 1,101, Level: 18
    Level completed: 1%, Points required for next Level: 99
    Encrypted's Avatar
    1066
    9
    Tasker, a little complicated but well worth it.
    31 days registered7 days registered250 Experience Points100 Experience PointsCreated Album pictures
    Adartilth's Avatar
    14211
    New York
    Locale. Expensive but not to complicated. Lol
    Points: 1,954, Level: 26
    Level completed: 54%, Points required for next Level: 46
    RolandDeschain's Avatar
    43
    Kirkland, WA
    203
    12 times
    Tasker is by far the best option, but it's also by far the most complicated. You can do amazing things with it, though; truly 22nd-century nerd science fiction-type stuff. I read a blog article somewhere about how a dude got his phone setup to start reading off his grocery list when he walked into the grocery store with Tasker, including holiday shopping reminders like reminding him to buy fireworks for the 4th of July.
    Points: 1,563, Level: 22
    cooksterman's Avatar
    6973
    45
    Sure, go to the market and grab CCH Cuztom Car Home. It has both of those settings available when yo set up preferences. Ive been usung CCH for over a month...extensively and love it.
    Points: 3,360, Level: 36
    Level completed: 7%, Points required for next Level: 140
    sluzbenik's Avatar
    385
    145
    For turning on Bluetooth and doing stuff when you're docked, Tasker is just as easy as Locale and a lot cheaper.
    Doing stuff like turning no your wifi within range of your house, and setting locations - well, that's tricky.
    Community Award
    434
    Pittsburgh, Pa
    678
    30 times
    Ok so after some research I downloaded tasker. Any advice on how to accomplish my needs within the program?
    Points: 1,746, Level: 24
    Level completed: 46%, Points required for next Level: 54
    Wasson101's Avatar
    6803
    Quote Originally Posted by AdamTomaino View Post
    Open up tasker, click "new" to set up a new profile
    name it "Car Dock Mode"
    You will now see a "First Context" menu, select the option "state" and then select "docked"
    you will now have a pulldown menu that asks for "Type" and is defaulted to "Any". Pull down the menu and select "Car" and then select "Done"
    You will now be in the "Task Edit" Screen
    Click the "new" option in the top right corner, name this task "Car Dock Enter"
    Click the "+" sign in the bottom left, and then select "Net" and then "Bluetooth"
    In the pulldown menu select "On" and click done
    Click the "+" sign in the bottom left again, and then select "Misc" and then "GPS"
    In the pulldown menu select "On" and click done.
    Now click "new" again in the top right and name the new task "Car Dock Exit"
    In the pulldown menu select "Off" and click done
    In the pulldown menu select "Off" and click done.
    Click the "Done" button on the bottom of the screen, this will bring you back to the "Profiles" screen
    Click on the "Car Dock Mode" profile, it should expand down, click on the car dock enter task (It will have a green arrow by it)
    Select "Add Exit Task"
    Pull down the menu that says "Anonymous" and select "Car Dock Exit"
    Select Done
    Hit Apply
    And you should be good to go!
    Points: 9,208, Level: 64
    Level completed: 53%, Points required for next Level: 142
    Overall activity: 2.9%
    Asharad's Avatar
    294
    Tiamat
    1,093
    17 times
    Just leave BT and GPS on all the time. They don't consume power unless you are using them. And I'm only using them in my car......
    Seriously, I leave them on all the time and see no battery drain.
  1. 3G stays on when I enable WiFi
    By antthedrag in forum Droid X Help
    Last Post: 07-29-2010, 11:12 PM
  2. Change Notification Settings When Docked?
    By zoomzoom9 in forum Droid X General Discussion
    Last Post: 07-27-2010, 01:24 PM
  3. Doesn't Stay Lit When Docked?
    Last Post: 07-25-2010, 03:02 PM
  4. Auto-sync auto disables?
    By James in forum Droid X Help
    Last Post: 07-22-2010, 03:31 AM
  5. how do i use or enable swype?
    By silent1643 in forum Droid X Help
    Last Post: 07-18-2010, 03:15 PM
android turn on gps when docked
atrix auto enable bluetooth when docked
auto enable gps
enable GPS on Droid X
how to enable gps on droid x
how to set auto gps
tasker bluetooth
tasker gps car dock
turn bluetooth on when docked
turn on gps droid x
