Root Help!
This is a discussion on Root Help! within the Droid X Hacks forums, part of the Droid X Development category; I need help rooting my droid x. No program I use will work. It says that its rooted but then when I use root checker ...
Results 1 to 2 of 2
Thread: Root Help!
    Root Help!
    I need help rooting my droid x. No program I use will work. It says that its rooted but then when I use root checker or go into a terminal it doesn't say it has access to root. My android version is 2.3.4 and the System version is 45.621.10Mb810. thanks
    Points: 18,680, Level: 86
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Framaroot use 1.4 or 1.6 new ones don't work as well with motorolas
  1. Root, root, root for the home team
    By jeems in forum New Member Introductions & Site Assistance
    Last Post: 06-21-2011, 08:42 PM
  2. Temp Root! Thanks to aliasxerog for post. This could lead to full root!
    By goblueboy in forum Everything about Gingerbread
    Last Post: 03-29-2011, 12:48 AM
  3. Replies: 17
    Last Post: 12-22-2010, 08:27 AM
  4. Replies: 3
    Last Post: 12-06-2010, 09:33 PM
  5. Mobile root vs. ADB root vs. one touch root?
    By Wicken in forum Droid X Hacks
    Last Post: 10-28-2010, 02:44 AM
