bricked droid x please help
This is a discussion on bricked droid x please help within the Droid X Hacks forums, part of the Droid X Development category; ok so a guy at work told me he has a Droid X like mine but a few days b4 he was messing around with ...
Results 1 to 10 of 13
Thread: bricked droid x please help
    Points: 1,734, Level: 24
    Level completed: 34%, Points required for next Level: 66
    Overall activity: 6.1%
    earlybill1's Avatar
    40965
    15
    ok so a guy at work told me he has a Droid X like mine but a few days b4 he was messing around with it and said now he cant do anything with it , basically it wont even turn on or off until the battery dies. So when it turns on the 1st screen is a Andy ( the droid guy ) with a big triangle and big explanation mark (!). so im was thinking it was bricked it would be a easy fix for me, so i gave him $20 for it. I got home put it in bootloader mode by pressing volume buttons up/down while holding power on ,it worked so far then i put in my froyo flashable cd went thru all that pressed 1 and it started all files said 100% and also said OK next to them . Then i followed the instruc. and pulled battery then held home key and power on key as it booted but this is where it didnt work ( ive had my Droid X for 4 plus yrs and have flashed many rom,changed from froyo to gingerbread 602,605 and back and forth many many times so i know a little bit) . So when it booted from me holding home/power keys it went back to bootloader mode and a few lines down it say ERR,68,70,70,and i think 1F. so i dont know what to do know i dont even know if it on a stock rom or even rooted and the guy didnt even know . so ive tried every other way of turning it on but every time it does come on it goes straight to bootloader mode i think its 30.04. Is X no good anymore or is there hope that it can be fixed . if anyone can please give me some help and advice i would be so happy thanks to all
    Points: 51,689, Level: 100
    Overall activity: 99.9%
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    I'm guessing it was running the .621 update. That can't be rolled back to a previous one. But the good news is it can be fixed. I'm at work now, but someone will be along shortly to aid you.
    Sent from my Galaxy Nexus using Xparent BlueTapatalk 2
    Points: 29,424, Level: 99
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    you already got the process down.. but like fez said.. it's running the .621.. which can't be rolled back.. so all you gotta do is just flash the .621 sbf.. and it should be good to go
    Post Script:
    Nemo Aeternamn Wallpapers
    earlybill1's Avatar
    40965
    15
    Quote Originally Posted by Nemo aeternamn View Post
    Im not sure if I have that files to make the cd but im gonna try now to find it and ill let you know thanks for ya'll's help
    Points: 18,472, Level: 86
    Level completed: 25%, Points required for next Level: 378
    Overall activity: 56.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    earlybill1's Avatar
    40965
    15
    Ok Ive found all kinda downloads for the linux iso cd 621 with root to get the Droid X back up and running but every time I download a file or zip or iso file it does not work . I download **** every day with no probs trust me I have all boxes checked for mock plus isbn debugging and unknown sources so why won't it download I've never had this prob help please
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    USB debugging and unknown sources shouldn't have any thing to do with downloading
    but you need a PC or Mac to burn iso to CD or flash drive then boot from that CD/usb
    Sent from my Amazon Kindle Fire using Tapatalk 2
    earlybill1's Avatar
    40965
    15
    Yea I know that but my work DROID x wont download the iso file to make the cs all the links i've tried just gives me an error I've got the other cds from group to gingerbread 596 602 and 340 but not 621 help lol
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    you try stock browser?
  1. I think I bricked my Droid X while .sbf'ing
    By droidxerps3 in forum Droid X SBF
    Last Post: 07-15-2012, 10:39 AM
  2. Droid X Bricked?
    By 408dan in forum Droid X Rooted Issues
    Last Post: 03-06-2012, 01:20 AM
  3. Bricked droid x2, need help!!!
    By CristianWasHere in forum Droid X2 General Discussion
    Last Post: 12-01-2011, 06:50 PM
  4. Bricked My Droid X
    By StR82Sn0W in forum Droid X Rooted Issues
    Last Post: 03-19-2011, 07:06 AM
  5. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
Z4root download
free download ?droid x 621-sbf-and-rootcd-2nd edition (2) (1).iso?
sd shadow dev-host droid
