Turn Droid X into a mini computer?
This is a discussion on Turn Droid X into a mini computer? within the Droid X Hacks forums, part of the Droid X Development category; I got the SIII and cleared the Droid X, reset it to factory. What I am not sure is possible is, can I get the ...
Results 1 to 7 of 7
Thread: Turn Droid X into a mini computer?
    Points: 2,674, Level: 31
    Level completed: 50%, Points required for next Level: 76
    Overall activity: 1.8%
    minigts's Avatar
    2709
    78
    I got the SIII and cleared the Droid X, reset it to factory. What I am not sure is possible is, can I get the phone working without it trying to connect to the network and just use it as if I didn't have phone service on it? It has been rooted and I have the files to root it, but wasn't sure if it would still try and connect via the radio for the phone.
    Do I need just to put a rooted image on it and start using it? I don't remember if there is a setting to turn off the cell radio and still have the wireless radio work.
    Points: 13,902, Level: 76
    Level completed: 63%, Points required for next Level: 148
    Overall activity: 78.9%
    DroidXFanatic's Avatar
    52093
    Nov 2011
    1,104
    42 times
    Just put it in airplane mode and leave it like that. That will shut off all network connectivity but you can still connect to WiFi.
    Sent from my Galaxy Note2 using Tapatalk 2
    minigts's Avatar
    2709
    78
    Quote Originally Posted by DroidXFanatic View Post
    Just put it in airplane mode and leave it like that. That will shut off all network connectivity but you can still connect to WiFi. Sent from my Galaxy Note2 using Tapatalk 2
    Duh, didn't think about that! Thanks for the reminder. Is there a way to get around the activation screen? I want to simply use it as a mini computer
    Points: 17,224, Level: 83
    Level completed: 75%, Points required for next Level: 126
    Overall activity: 99.8%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    4,125
    437 times
    Like this
    Attached Images Attached Images
    minigts's Avatar
    2709
    78
    Quote Originally Posted by clothednblack View Post
    Like this
    Thanks for this. I tried, but it doesn't seem to work (for me). I have a rooted version of .621, not sure if that makes a difference. I tried touching #1, sliding to #2 and so on. Also tried touching #1, #2, etc. Continuing just in case I'm doing something wrong, but can you confirm if it's a slide to each number? Assuming it is based on the drawing.
    minigts's Avatar
    2709
    78
    Quote Originally Posted by minigts View Post
    Nevermind, I was touching in the status bar. I'm an idiot. I tend to say that a lot when trying to do stuff like this. :\ Thanks for the note!
    51337
    Nov 2011
    Smith river CA
    4,125
    437 times
    Sorry, I was busy. Glad you got it, I forgot to specify the touch not drag lol
  1. Replies: 0
    Last Post: 05-10-2012, 06:23 AM
  2. MINI on DROID X2
    By tylermcmuffin in forum Droid X2 Hacks
    Last Post: 09-19-2011, 11:15 PM
  3. Replies: 1
    Last Post: 12-13-2010, 11:37 AM
  4. Replies: 0
    Last Post: 10-03-2010, 10:29 AM
droid mini forums discussions
droid x into a fomputer
how to turn droid into computer
turn droid into .
turn droid x into mini computer
turn droid x into pc
turn my droid x into a comouter
