I just rooted my .621 droid x to .604 Milestone X. How do I overclock this sucker? Do I need to install Cyanogen mod?
This is a discussion on is overclocking possible with Milestone X? within the Droid X Hacks forums, part of the Droid X Development category; I just rooted my .621 droid x to .604 Milestone X. How do I overclock this sucker? Do I need to install Cyanogen mod?...
For future reference .621 is now rootable. [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF) You won't have to deal with a milestone x if you just follow those instructions. If you want to stay on milestone then try milestone overclock from the play store. Most people that overclock the x use jrummy16's Droid Overclock from play but i'm not 100% sure if it works with milestone.
Jrummy overclock works on 621/604
