This is a discussion on [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF) within the Droid X Hacks forums, part of the Droid X Development category; Please help stuck where its supposed to reboot it just goes to bootloader says bootloader 30.04 code corrupt batteryok ok to program transfermode usb Tried ...
Page 8 of 25 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 243
Like Tree14Likes
Thread: [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF)
  1. #71
    Points: 192, Level: 3
    Level completed: 84%, Points required for next Level: 8
    Overall activity: 5.9%
    31 days registered100 Experience Points7 days registered
    mdsco's Avatar
    62988
    Nov 2012
    23
    bootloader 30.04
    code corrupt
    batteryok
    ok to program
    transfermode
    usb
    Tried battery pulls, usb all that multiple times restarted the software it just says daemon started successfully
  3. #72
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Did you verify the md5 to ensure it was correct ?
  4. #73
    mdsco's Avatar
    62988
    Nov 2012
    23
    Posted this once so it might double post. I downloaded the program to check the md5 but didnt understand it. I figured if it was posted on this forum and it worked for other people it was fine. Why would it be bad but still work for other people? So now what?
  5. #74
    Points: 18,811, Level: 86
    Level completed: 93%, Points required for next Level: 39
    Overall activity: 70.4%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    try MD5 Checker it's a little simpler, use to verify the hash/checksum to ensure the file integrity is correct with the matching file.
    The MD5 checksum for a file is a 128-bit value, something like a fingerprint of the file.
    that's why you use md5 checksum, to verify that the file downloaded correctly
    bootloader 30.04
    code corrupt
    I think you need to flash .sbf now
    edit:
    Droid2_D2G_DX_DX2-RootCD-2012.iso
    md5 Hash:7BAEE9C34F6EF7AD0B4FA219AE387C68
    sha-1 Hash: 6D2A2019D746BBBCF0A92FFB60305B793381EDA6
  6. #75
    mdsco's Avatar
    62988
    Nov 2012
    23
    Thanks, got a link to a forum on how to flash the .sbf. i am a noob
  7. #76
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    fyi
    MD5 (1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US.sbf.zip) = 06bbf7ee86c0ed64654e14bcb84c4aed
    you should always verify md5 checksum on large files
  8. #77
    Points: 1,958, Level: 26
    Level completed: 58%, Points required for next Level: 42
    klickin2k's Avatar
    6279
    25
    Ok, just rooted from stock .621 and root took perfectly. I have installed Liquid Smooth v1.5 and that is working pretty good also. What other ROMS can be installed without having to revert back to a previous version? I've seen someone say CM9 works, but can any GB ROMS be installed on top of this root method? Thanks.
  9. #78
    Points: 3,902, Level: 39
    Level completed: 68%, Points required for next Level: 48
    EllenR's Avatar
    34803
    64
    We have a stock 4.5.621 and I d/l and built the magic md5. The CD boots OK, so I am ready to go.
    just wonder if this will kill ANYTHING that is on this unrooted Droid X? We have MyBackup Pro v 3.2.5 now, but am not sure if it is saving everything as the phone is not rooted now.
    I guess this is a long way of asking if I can root without killing my apps and/or data?
  10. #79
  11. #80
    EllenR's Avatar
    34803
    64
    Rooting wont touch your apps or data.
    Thank you. I guess our main reason to root is that we want to use MyBackup Pro to save EVERYTHING..apps and data. I guess it will do this if we are rooted, even if the apps are not "integrated".
  1. x2/milestone root question
    By acid_rain74 in forum Droid X2 Hacks
    Last Post: 04-30-2012, 02:39 AM
  2. Replies: 1
    Last Post: 04-17-2012, 12:06 PM
  3. Alltel milestone x root
    By wfo in forum Droid X General Discussion
    Last Post: 12-09-2011, 09:40 PM
  4. Milestone x root help
    By thore022 in forum Milestone X Hacks
    Last Post: 10-10-2011, 11:34 AM
  5. magic pixle fixer!!!!?????
    By ianreed in forum Droid X General Discussion
    Last Post: 01-02-2011, 03:59 PM
Root droid x
droid x 4.5.621 root
droid x root
how to root droid x
how to root droid x 4.5.621
magic md5
magic md5 root
root droid x .621
root droid x 621
