This is a discussion on [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF) within the Droid X Hacks forums, part of the Droid X Development category; Originally Posted by sd_shadow if pressing the power button doesn't reboot, pull battery, and reboot was sbf_flash able to flash file? Sent from my DROID ...
Page 3 of 25 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 243
Like Tree14Likes
Thread: [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF)
  1. #21
    Points: 65, Level: 1
    Level completed: 30%, Points required for next Level: 35
    Overall activity: 0.7%
    7 days registeredTagger Second Class
    TheHokeyPokey's Avatar
    61736
    Sep 2012
    8
    Got it thanks!!
  3. #22
    Points: 1,941, Level: 26
    Level completed: 41%, Points required for next Level: 59
    stoph8n24's Avatar
    21743
    29
    So for the ppl on Milestone X n already have roms installed, really don't need this, correct? My phone has been lagging on Liquid 321, so I wiped n flashed to CM, looking for new stuff that's all. Tia
  4. #23
    Points: 28,483, Level: 99
    Level completed: 9%, Points required for next Level: 1,517
    Overall activity: 37.7%
    7,093
    338 times
    If you already rooted using the milestone method then no you wont need this. This is just an alternative way to root without having to go through all that. Did you flash the .621 kernel back to your phone after sbfing it to .604?
  5. #24
    stoph8n24's Avatar
    21743
    29
    Unsure, it was a while I did it. Been on my work phone more. Wanted to try new roms n what not but whatever is compatible. Here is what I'm on
    Attached Images Attached Images
  6. #25
    Points: 1,394, Level: 20
    Level completed: 94%, Points required for next Level: 6
    dwm650's Avatar
    34841
    bhigham/beh modified the root method
    based on New D2 root method for stock 2.3.4 (621/622) found (Droid2, R2D2)
    How this works
    Originally Posted by phifc
    There's an exploit in loadpreinstall.sh. It compares md5 sum files of preinstalled apps and if they're different, copies the md5 to the local cache. The preinstall just has an empty file in app/ so it will parse the md5 for it. Instead of an md5 sum, it contains a local.prop that allows adb root shell. So the system thinks it's copying the md5sum to the cache when it bounces off the symlink and overwrites the /data/local.prop, giving adb root on next reboot
    Droid2_D2G_DX_DX2-RootCD-2012.iso
    has options for D2, D2G, DX, and DX2
    burn image to cd with imgburn, (Instructions, Window 7 - Vista and XP)
    or flash drive use UNetBootin for Windows (Instructions from pendrivelinux.com)
    basically read onscreen directions
    Reboot PC
    Hit F12 (sometimes F8 or esc) during boot to go to boot menu
    Select drive image is on
    wait for yellow "boot baby... boot" screen
    You will see yellow dots for 3-5 minutes then the script will start
    select DX
    don't use numbers on right side of you keyboard, just use the ones above qwerty
    turn phone on, connect to pc with usb cable
    check usb debugging (settings/apps/development)
    select charge only usb mode
    press continue I get to this point & it does not do anything. Am I suppose to be in bootloader on just phone on ?
    adb will push
    Code:
    data/local.prop /data/preinstall_md5/magic.md5
    reboot phone to bootloader (Hold volume up+down buttons and power button, or hold Vol.Down and Camera and wait for the screen to flash)
    repacked sbf will be flashed (less than 50mb)
    phone will, reboot twice, very important (reboot just replaces the local.prop, but the old local.prop is still in memory, till second reboot)
    adb pushes su,superuser, and busybox
    reboot to recovery, wipe cache (should auto reboot to recovery, at android andy press both volume buttons, if it doesn't press home button and hold it in then press your power button, hold it in also till you see a triangle on the screen w/ android andy then press both volume buttons)
    then select reboot
    rooted
    again most of these steps are just click continue
    updated 07 Sept 2012
    25 Sept 2012 added bootloader and recovery details
    So what Am I doing wrong ?
  7. #26
    Points: 18,472, Level: 86
    Level completed: 25%, Points required for next Level: 378
    Overall activity: 56.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    phone needes to be on so you can select usb debugging and charge only mode, does the program say anything
    try toggling usb debugging on/off
  8. #27
    dwm650's Avatar
    34841
    I got it thanks to sd_shadow .
    I also uninstalled & reinstalled usb drivers.
    Also used the usb port close to the A/C power port on my laptop.
  9. #28
    Points: 1,133, Level: 18
    Level completed: 33%, Points required for next Level: 67
    Overall activity: 4.3%
    vampyric's Avatar
    62266
    Oct 2012
    redding, ca
    29
    droid x root
    i was wondering if this is the most up to date method to rooting droid x on .621 build?
    and is it still reffering to using a linux based o.s. like Ubuntu?
    new to alll this so any help is greatly appreciated!
  10. #29
    7,093
    338 times
    This is the only direct root method for .621. There is another but it requires you to SBF to .604 milestone.
    And no you don't need to be on a Linux machine (if that's what you're asking?)
    Sent from my X2 using DXF
  11. #30
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    you download an iso file that contains an linux os that runs from a cd or usb drive
    Sent from my MB870 using Droid X Forums
  1. x2/milestone root question
    By acid_rain74 in forum Droid X2 Hacks
    Last Post: 04-30-2012, 03:39 AM
  2. Replies: 1
    Last Post: 04-17-2012, 01:06 PM
  3. Alltel milestone x root
    By wfo in forum Droid X General Discussion
    Last Post: 12-09-2011, 10:40 PM
  4. Milestone x root help
    By thore022 in forum Milestone X Hacks
    Last Post: 10-10-2011, 12:34 PM
  5. magic pixle fixer!!!!?????
    By ianreed in forum Droid X General Discussion
    Last Post: 01-02-2011, 04:59 PM
Root droid x
droid x 4.5.621 root
droid x root
how to root droid x
how to root droid x 4.5.621
magic md5
magic md5 root
root droid x .621
root droid x 621
