This is a discussion on [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF) within the Droid X Hacks forums, part of the Droid X Development category; Great, I could use a million dollars, lol...
Page 25 of 25 FirstFirst ... 15232425
Results 241 to 243 of 243
Like Tree14Likes
Thread: [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF)
  1. #241
    Points: 18,680, Level: 86
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
  3. #242
    Hello every body,
    A month ago I received an Droid x phone (MB810A).
    I recharged battery outside.
    It has bootloader 30.04 version.
    Phone was stuck in system recovery menu.
    I downloaded .621 sbf and
    I got in bootloader menu
    I successfully flashed it using rsd, command in linux and this DX ezSBF livecd
    I have done wipe data and also wipe cache (these are in system recovery menu).
    I also restarted two times....
    After each above it restarts in system recovery menu.
    I do not know how to restart it normally.
    Somebody advised me that could be a hardware problem - but the phone starts well in system recovery menu.
    I have red many forums some of the users succeed others not. Are there some procedure?
    I need help - step by step.
    Thank you.
  4. #243
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    If you flashed sbf and wiped data, problem is hardware failure, and there is no fix.
    Sent from my XT894 using Tapatalk
  1. x2/milestone root question
    By acid_rain74 in forum Droid X2 Hacks
    Last Post: 04-30-2012, 03:39 AM
  2. Replies: 1
    Last Post: 04-17-2012, 01:06 PM
  3. Alltel milestone x root
    By wfo in forum Droid X General Discussion
    Last Post: 12-09-2011, 10:40 PM
  4. Milestone x root help
    By thore022 in forum Milestone X Hacks
    Last Post: 10-10-2011, 12:34 PM
  5. magic pixle fixer!!!!?????
    By ianreed in forum Droid X General Discussion
    Last Post: 01-02-2011, 04:59 PM
Root droid x
droid x 4.5.621 root
droid x root
how to root droid x
how to root droid x 4.5.621
magic md5
magic md5 root
root droid x .621
root droid x 621
