This is a discussion on [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF) within the Droid X Hacks forums, part of the Droid X Development category; Try around here https://motorola-global-portal.custh...r-my-device%3F...
Page 2 of 25 FirstFirst 123412 ... LastLast
Results 11 to 20 of 243
Like Tree14Likes
Thread: [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF)
    hei, where do i get the SBF file, i didn't see any link in the post
    soory for being noob
    anyone?
    Points: 6,333, Level: 51
    Level completed: 92%, Points required for next Level: 17
    Sefirosu's Avatar
    28086
    Boston, Ma
    565
    So I'm trying this and the screen on the laptop is just hanging at * daemon started successfully *. Been hanging out there for like 10 minutes. Any suggestions?
    Points: 18,472, Level: 86
    Level completed: 25%, Points required for next Level: 378
    Overall activity: 56.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by TheHokeyPokey View Post
    My droid X doesn't have a USB connection notification allowing me to select charge only mode. Is there a driver I need to install to my PC?
    phone should give usb options, even if pc doesn't have correct drivers
    maybe bad usb cable
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by Sefirosu View Post
    try toggling usb debugging off/on
  8. #17
    Points: 17, Level: 1
    Level completed: 33%, Points required for next Level: 33
    bluecap's Avatar
    61840
    Sep 2012
    Toggling "USB Debugging" on/off didn't work for me, but I tried a different USB port on my computer (when you're stuck at that message, it's still ok to unplug it and replug it in), and it worked fine for me with no errors. As mentioned in the original, it guides you through all the steps except how to get to clearing cache from the triangle/android screen (both volume buttons, clear cache, reboot). Thanks to the OP for the rooting instructions.
    sd_shadow likes this.
  9. #18
    Points: 65, Level: 1
    Level completed: 30%, Points required for next Level: 35
    Overall activity: 0.7%
    7 days registeredTagger Second Class
    TheHokeyPokey's Avatar
    61736
    Sep 2012
    8
    Stuck on the bootloader before the step where I'm supposed to reboot twice, please help!!
  10. #19
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    if pressing the power button doesn't reboot, pull battery, and reboot
    was sbf_flash able to flash file?
  11. #20
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by bluecap View Post
    added more bootloader and recovery details to op
  1. x2/milestone root question
    By acid_rain74 in forum Droid X2 Hacks
    Last Post: 04-30-2012, 03:39 AM
  2. Replies: 1
    Last Post: 04-17-2012, 01:06 PM
  3. Alltel milestone x root
    By wfo in forum Droid X General Discussion
    Last Post: 12-09-2011, 10:40 PM
  4. Milestone x root help
    By thore022 in forum Milestone X Hacks
    Last Post: 10-10-2011, 12:34 PM
  5. magic pixle fixer!!!!?????
    By ianreed in forum Droid X General Discussion
    Last Post: 01-02-2011, 04:59 PM
Root droid x
droid x 4.5.621 root
droid x root
how to root droid x
how to root droid x 4.5.621
magic md5
magic md5 root
root droid x .621
root droid x 621
