This is a discussion on [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF) within the Droid X Hacks forums, part of the Droid X Development category; i would just install d2 bootstrap i have written some instructions just look for how to use d2 bootstrap ere sd_shadow's list of links for ...
Page 15 of 25 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 243
Like Tree14Likes
Thread: [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF)
  1. #141
    Points: 18,680, Level: 86
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    sd_shadow's list of links for Droid FAQs, SBF, Rooting, ROMs.... https://docs.google.com/document/d/1...0UWIlXLWA/edit
    Sent from my XT862 using Droid X Forums
  3. #142
    I saw the google doc on the bootstrap...I just wanted to make sure that I didn't mess things up by doing what I did in that sequence and for selecting Droid 2 as the device instead of DX as you state in that google doc. thanks
  4. #143
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    for D2, D2G, R2D2, and DX, you need to install D2 bootstrap then,
    to select DX 2nd init recovery (in Rom Manager), so that its compatible with 2nd init roms
  5. #144
    Then backup stock ROM via CWM?
    If that is correct, would it be advisable to backup EFS file (is there an app to do this?) as well as apps on phone (can use Titanium Backup Pro)..correct? thanks
  6. #145
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    I recommend making a nandroid backup after rooting, and before any major changes
    I have never used Encrypting File System, so not sure
    titanium backup pro is a very usefully app, I use it every time I install a new rom
    lokewolf likes this.
  7. #146
    "Reboot into Recovery" in CWM (Rom Mgr) or "backup current ROM"?
  8. #147
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    ok you asking about /efs folder?
    This is a very sensitive system folder that contains Phone-specific information such as the IMEI (encrypted in the nv_data.bin), wireless devices MAC addresses, product code (also in the nv_data.bin), and much more. Often users trying to change product codes or trying to unlock the mobile will end up corrupting data in this location.
    I think that it is untouchable, because of the locked bootloader, I have never had a problem, and have flashed roms/sbfs a hundred times on D2, D2G, DX2 and D3
  9. #148
    You hadn't gave info on EFS folder for backing it up, but you directed to make a backup (nandroid). So reading your google doc it says "tap on Reboot Recovery" so I just wanted to be crystal clear on what you meant and what I see in Rom Mgr (CWM). thanks
  10. #149
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    I have never had much use for rom manger, I just use bootstrap to reboot to cwm
    edit; rom manager is not cwm recovery, it is an interface to cwm
  11. #150
    oh yeah...recalling the other option on the bootstrap app...to recover..
    good to know about Rom mgr and cwm. So did I gaff by using Rom Mgr to flash cwm recovery?
  1. x2/milestone root question
    By acid_rain74 in forum Droid X2 Hacks
    Last Post: 04-30-2012, 03:39 AM
  2. Replies: 1
    Last Post: 04-17-2012, 01:06 PM
  3. Alltel milestone x root
    By wfo in forum Droid X General Discussion
    Last Post: 12-09-2011, 10:40 PM
  4. Milestone x root help
    By thore022 in forum Milestone X Hacks
    Last Post: 10-10-2011, 12:34 PM
  5. magic pixle fixer!!!!?????
    By ianreed in forum Droid X General Discussion
    Last Post: 01-02-2011, 04:59 PM
Root droid x
droid x 4.5.621 root
droid x root
how to root droid x
how to root droid x 4.5.621
magic md5
magic md5 root
root droid x .621
root droid x 621
