Need advice!
This is a discussion on Need advice! within the Droid X Hacks forums, part of the Droid X Development category; That is by far the easiest way. Good luck! Sent from my Black Iced X...
Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 93
Like Tree11Likes
Thread: Need advice!
    Points: 3,098, Level: 34
    Level completed: 32%, Points required for next Level: 102
    Overall activity: 7.9%
    newmanx4's Avatar
    34469
    703
    27 times
    Points: 178, Level: 3
    Level completed: 56%, Points required for next Level: 22
    Overall activity: 8.7%
    SonOfAnarchy0210's Avatar
    61005
    Aug 2012
    55
    Change of plans, I found a pack of brand new blanks in the closet lol. So will someone please maybe 'dumb it down' for me. I am a noob lol.
    61005
    Aug 2012
    55
    Quote Originally Posted by newmanx4 View Post
    This is a new root method for the DX running .621. It has been confirmed to work. It is an .ISO file that you burn to CD then boot your PC from the disc. Then it does the work for you. The phone has to be in Bootloader while this is done. You'll also need to make sure you have the latest Motorola drivers on the PC.
    How do I boot my PC from the disk?
    Sorry for the hassle, just being cautious
    EDIT: How do I burn the iso? Also where is the iso? I got a .zip file from the link and extracted it but I dont see any iso
    61005
    Aug 2012
    55
    And do I need to download and place superuser on the sc card before I do anything?
    newmanx4's Avatar
    34469
    703
    27 times
    To put the phone in bootloader:
    From a powered off state, press and hold Camera, Volume down, then Power until you see a quick flash on the screen. Let off the buttons and you'll be in bootloader. Screen will be black with white text and will say Bootloader 30.04.
    To boot from the disk you'll need to restart the PC and watch for it to tell you what to hit to go to setup. My laptop uses F12 but yours may be different. Google it.
    Superuser will be installed during the root process automatically. Nothing to download.
    Make sure the battery is at least 80% before you start in case you run into any trouble. If something goes wrong and the phone won't boot don't panic. Its fixable.
    Once you're rooted and ready for a ROM there's a whole other set of steps to take to make that happen.
    Once its rooted follow these steps. Place the ROM zip on the root of the SD card (meaning not in any folders). Then:
    1. Install Droid 2 Bootstrap ($2 in the market but you've got to have it)
    2. Install ROM Manager Lite. (Free in the market)
    3. Open D2 Bootstrap. Hit Bootstrap Recovery. Close the app.
    4. Open ROM Manager. Select Install Latest Clockwork. Should be the top choice. When the device list pops up choose Droid X 2nd init.
    5. In ROM Manager choose Reboot Recovery. Phone will boot into Clockwork. Black screen with blue text.
    6. Once in Clockwork do a data wipe and cache wipe. Volume keys to navigate, Camera button to execute.
    7. Install ROM zip from SD card.
    8. Reboot
    One thing: Once you've used Bootstrap, NEVER hit Bootstrap Recovery again or you'll be starting from scratch again.
    And since this is your girlfriends phone make sure she understands this will erase everything on the phone. You better back up anything you can. You can send contacts to SD and import them back. If they're all synced with Google they'll come back automatically. Same with the calendar.
    SonOfAnarchy0210 likes this.
    61005
    Aug 2012
    55
    Yea I made that very clear to her lol I can hear her now.. (*cringes*)
    But she has them backed up via Google so we are good to go. Thank you very much for your help I REALLY appreciate it. Likely going to do this tonight thx to you!!!
  8. #17
    61005
    Aug 2012
    55
    Can someone tell me exactly how I burn the ISO? Do I need a special program to do so? Also, Do I burn the zip that I downloaded or do I need to extract it and burn something it contains?
  9. #18
    newmanx4's Avatar
    34469
    703
    27 times
    Are you running Windows? It has a built in ISO burner. Once you've downloaded the ISO just right click it and send to disc. Or you could download a free program named Imageburn to do it with.
  10. #19
    Points: 8,462, Level: 62
    Level completed: 4%, Points required for next Level: 288
    Overall activity: 99.6%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    2,987
    120 times
    Nero Burns ISO but not sure if there is a free version, may want yo check freedownloads.com and see if they have an ISO file burner. It needs to be extracted if I remember right.
    teleported from my wizardry DX
    Edit.....http://download.cnet.com/Active-ISO-Burner/3000-2646_4-10602452.html
  11. #20
    61005
    Aug 2012
    55
    Is the iso the zip? I'm not trying to be difficult but like I said I am a noob and some SPECIFIC details would be nice.
  1. need advice
    By justme0485 in forum Droid X ROMs
    Last Post: 11-20-2011, 12:12 AM
  2. [Advice?] GB .588 to ???
    By Kr0n0Tr1pR in forum Gingerbread General Discussion
    Last Post: 05-18-2011, 11:23 AM
  3. Looking for some advice
    By Godrik1210 in forum Droid X ROMs
    Last Post: 02-22-2011, 10:15 AM
  4. Need some advice
    By Mckilljoyy in forum Droid X Themes
    Last Post: 12-02-2010, 12:20 AM
  5. Some advice please
    By Matt6906 in forum Droid X ROMs
    Last Post: 10-29-2010, 06:20 PM
droid2 d2g
droid2 d2g dx
droid2 d2g dx dx2-rootcd-2012
droid2 d2g dx dx2-rootcd-2012.iso
droid2 d2g dx dx2-rootcd-2012.iso tutorial
droid2 d2g dx2-rootcd-2012
liquid wizardry ics dx
mcbk83@l93
steel droid 2.6.32.9-g1282440 mcbk83@il93lnxdroid08 #1
why droid2 d2g dx2-root cd-2012.iso won't download
