Stagefright / build.prop / Music player issues
This is a discussion on Stagefright / build.prop / Music player issues within the Droid X Hacks forums, part of the Droid X Development category; After doing an SBF flash and then installing the leaked 2.2 FroYo ROM, I've had few issues. However, one issue I am having is a ...
Results 1 to 7 of 7
Thread: Stagefright / build.prop / Music player issues
    Tagger Second Class31 days registered250 Experience Points7 days registered100 Experience Points
    JFMFT's Avatar
    283
    86
    7 times
    After doing an SBF flash and then installing the leaked 2.2 FroYo ROM, I've had few issues. However, one issue I am having is a random pausing/freezing of music when using the stock music player.
    I was wondering if anyone knew if changing the lines in build.prop to enable stagefright (=true instead of =false) might help this? I heard stagefright was made better in 2.2 by Google, though Motorola decided to not use it for some reason. However, it can be enabled by changing the build.prop file using root explorer.
    I am not sure if stagefright is just for video, or if it is also for audio, and if it may have an impact on using the stock music player. I am willing to try almost anything to stop my phone from freezing/pausing when using the stock music player.
    Anyone know anything about this? Any suggestions or other comments? Thanks.
    bamfsig45's Avatar
    84
    Wichita, KS
    382
    30 times
    I have that issue in 2.1
    JFMFT's Avatar
    283
    86
    7 times
    Really? I never had this issue prior to 2.2. Not once did my music player freeze! And I use my music player for 6-8 hours per day while at work, and usually 1-2 more hours each night when exercising, doing housework, etc.
    bamfsig45's Avatar
    84
    Wichita, KS
    382
    30 times
    Quote Originally Posted by JFMFT View Post
    Yep I too use my for 6-8 hours at work and its happened 2-3 times today already.
    JFMFT's Avatar
    283
    86
    7 times
    Quote Originally Posted by bamfsig45 View Post
    I did the following and it fixed my issues completely: go into settings -> applications -> manage applications -> find the application "Music" - click Force Stop (if it's running), then Clear Data, then Clear Cache (if it's not greyed out).
    Then reboot your phone. Should fix all your problems!
    aohus's Avatar
    5960
    79
    7 times
    just make sure you uninstalled all music related widgets. i had the same issue in 2.2 after i updated and deleted 'beautiful music widget' and everything was all good.
    most likely your stock player is conflicting with another music related process is my assumption.
    JFMFT's Avatar
    283
    86
    7 times
    Quote Originally Posted by aohus View Post
    No; I've never used a 3rd party application. So, this whole most likely stuff is, in fact, not most likely. My issues were "most likely" related to the upgrade process from 2.1 to 2.2 and the inherent need to (and thus my lack of remembering to) clear data/cache where possible.
  1. Editing the build.prop for more than just stagefright?
    By Phatkat66 in forum Droid X Hacks
    Last Post: 08-23-2010, 05:55 PM
  2. Replacement Music Player App?
    By Evelgest in forum Droid X Apps
    Last Post: 08-09-2010, 11:25 AM
  3. Music player Help!
    By freshgeardude in forum Droid X Help
    Last Post: 08-03-2010, 07:24 PM
  4. Music not showing up in music player.
    By Euphzilla in forum Droid X Help
    Last Post: 08-03-2010, 10:11 AM
  5. BEST Music Player for the DX?
    By Bill in forum Droid X Apps
    Last Post: 07-31-2010, 02:13 PM
Droid x build.prop stagefright
build.prop audio
droid x music player fix
how to enable stagefright
prop audio player
stage fright audio player
stage fright player
stagefright audio
stagefright audio player
stagefright player
