DX2 w/ Liberty ROM - Calendar problems
This is a discussion on DX2 w/ Liberty ROM - Calendar problems within the Droid X Hacks forums, part of the Droid X Development category; I installed the Liberty custom ROM on my Droid X2 a couple days ago. I have been happy with it (once I finally got it ...
Results 1 to 1 of 1
Thread: DX2 w/ Liberty ROM - Calendar problems
    Points: 522, Level: 10
    Level completed: 44%, Points required for next Level: 28
    goldberg1138's Avatar
    57376
    5
    I installed the Liberty custom ROM on my Droid X2 a couple days ago. I have been happy with it (once I finally got it working), but I'm experiencing a bug now. I can't access any calendar apps, including the stock app that came with Liberty, or any widgets I've downloaded. I get an error message:
    "The application Calendar (process com.android.calendar) has stopped working. Please try again"
    I get a similar message about Calendar Storage, and I've gotten an error about Poll Scheduler (I *think* that's what it was called). Liberty comes with 2 sets of Calendar/email apps - AOSP and Blur. All this seemed to start when I tried to switch from AOSP to Blur.
    I already tried doing a factory reset, which didn't fix the problem. I erased the internal storage, but not the SD card when I did this.
    Does anyone have any suggestions for how I can fix this problem? Does the factory reset wipe clean the cache? Should I try this? Do I need to re-flash the ROM on my phone? I would love to fix this, since I use google calendar extensively. Any help would be appreciated. Thank you.
  1. G-Calendar sync problems with Android
    By jcmexia in forum Droid X Help
    Last Post: 03-04-2012, 08:23 PM
  2. Calendar won't load on liberty v4
    By TheJustPull in forum Gingerbread Roms
    Last Post: 05-04-2011, 10:40 AM
  3. Liberty 1.5 calendar question
    By DrivetheGreen66 in forum Droid X ROMs
    Last Post: 02-17-2011, 02:58 AM
  4. Pure Grid Calendar event input problems
    By Yarzospatflute in forum Droid X Apps
    Last Post: 09-26-2010, 01:12 PM
  5. Calendar problems
    By brian226 in forum Droid X Help
    Last Post: 07-27-2010, 12:10 PM
dx2 rom
dx2 roms
dx2 root rom
how to fix internal storage issues with a custom rom on android
how to load liberty rom on dx2
installing a rom on my dx2
liberty rom
liberty rom droid x2 errors
liberty rom dx2
media gallery liberty rom not working
