Noob Friendly Verizon Root and CM7 ROM Guide for Droid X .621 OTA Update
This is a discussion on Noob Friendly Verizon Root and CM7 ROM Guide for Droid X .621 OTA Update within the Droid X Hacks forums, part of the Droid X Development category; I dont use swype, i dont think any rom has swype preinstalled. check out Swype | Text Input for Screens . Need to register, etc....
Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 132
Like Tree9Likes
Thread: Noob Friendly Verizon Root and CM7 ROM Guide for Droid X .621 OTA Update
  1. #21
    Points: 1,241, Level: 19
    Level completed: 41%, Points required for next Level: 59
    31 days registered250 Experience Points100 Experience Points7 days registeredTagger Second Class
    holycow131415's Avatar
    57026
    Mar 2012
    38
  3. #22
    Points: 161, Level: 3
    Level completed: 22%, Points required for next Level: 39
    Overall activity: 1.5%
    Loganhood's Avatar
    57249
    10
    Some comments and questions:
    I used your easy instructions and everything worked flawlessly for me, no problems! Then I flashed CM7 like it showed. I was also wondering if there was a way to get swype back I miss it! And also my battery life is completely awful! It didn't even last 8 hours while I was at work and I sent MAYBE 15 text messages total and that was all I used it for. And I know it wasn't any background apps draining it cause I don't have any downloaded yet after the reset. Any suggestions? And also if I have to flash another ROM for better battery life which one would be best? Since I used your instructions, I also went ahead and did the CM7, but can I use any ROM I want to now that its rooted? And if I can't, which ones can I flash? Sorry for the plethora of noob questions, I'm new. But I really appreciated your post!!!
  4. #23
    57026
    Mar 2012
    38
    See my above post about swype For battery life, make sure your screen brightness is all the way down, and install rom toolbox. I myself did notice about battery life, and here is my post Updated Info On RevNumbers CM4DX-GB(HDMI Out, 1% Battery, No Charge LED, FM radio, Charge While Off) - CyanogenMod [shadow] - RootzWiki - Page 410 about how it improved battery. It works now just like it used to About flashing any ROMs, yes you can, just make sure they are for the DX and gingerbread based. If you switch from ROM to ROM, you definitely will have to factory reset/clear data and clear cache, meaning youd have to install apps each time. if you just stick with the CM7 ROM and flash its updates, the most you will need to do is clear cache, which leaves those apps alone. CM7 imo is the most stable as I said in my previous post. You can check out the progression of ICS ROMs that are being developed actively too Droid X Development - RootzWiki but they are along way off.
    Loganhood likes this.
  5. #24
    Loganhood's Avatar
    57249
    10
    Awesome thanks. I love everything so far except the battery life. I bought ROM toolbox pro and set the profiles like your post showed. If the battery life improves I'll definitely stick with CM7. If it doesn't I'll try some other ROMs. And I downloaded Swype....worked like a charm!! Thanks for the help
  6. #25
    57026
    Mar 2012
    38
    Quote Originally Posted by Loganhood View Post
    Youre welcome, make sure the "use profiles" checkbox is checked at the right hand corner... i completely missed that when i first used it lol.
  7. #26
    Points: 137, Level: 2
    Level completed: 74%, Points required for next Level: 13
    Overall activity: 1.6%
    100 Experience Points31 days registeredTagger Second Class7 days registered
    aryavat's Avatar
    57311
    12
    went back to default milestone sbf..swype is important to me...and i had already been to the website you suggested for swype but some forum members suggested the swype beta available from that website makes a lot of typos. That is why i was looking for a way to get the stock swype back.
  8. #27
    Loganhood's Avatar
    57249
    10
    Yeah I found the "use profiles" box. And the swype is working perfectly! I've been using it for two years and I'm super fast at it and I reeeeeaally missed it when I got CM7 but then I downloaded the beta and everything works great!
  9. #28
    Loganhood's Avatar
    57249
    10
    I can't figure out how to get my phone to vibrate when I get a text tho. I've looked at all the settings and messed with em, but I can't figure it out. It'll vibrate when I get a call, so I know it's working, but it won't vibrate when I get a text.
  10. #29
    Points: 6,372, Level: 52
    Level completed: 11%, Points required for next Level: 178
    savagerun's Avatar
    41501
    2,204
    54 times
    Messaging app > menu > settings > vibrate.
  11. #30
    aryavat's Avatar
    57311
    12
    When i use wifi tether or barnacle wifi tether..it starts the tethering but connecting the laptop to it and opening any browser takes me to a verizon page saying "Your phone is not currently set up to be used as a modem or mobile hotspot" and outlines verizons hotspot plans. Opening any browser on the phone gives me the same message. It made my 3g stop working as well until i rebooted...anyone else has that issue? I am on milestone SBF rooted.
  1. Can D3 one click work on regular Verizon Droid X?? Sorry I'm a noob to all of this.
    By WTSLDROIDX213 in forum Gingerbread Development and Hacking
    Last Post: 11-29-2011, 12:52 PM
  2. When will droid get more corporate user friendly ?
    By plumcrazy in forum Droid X General Discussion
    Last Post: 04-24-2011, 07:18 PM
  3. Replies: 25
    Last Post: 12-06-2010, 10:39 PM
  4. Replies: 9
    Last Post: 09-09-2010, 02:30 PM
  5. Droid X (1st time Root) NooB
    By cloudsdale in forum Droid X Hacks
    Last Post: 07-25-2010, 11:05 PM
cm 7 droid x
cm7 droid x
cm7 droid x download
cm7 for droid x
cm7 on droid x
droid x .621 rom list
droid x cm7
droid x root
your phone is not currently set up to be used as a modem
your phone is not currently setup to be used as a modem
