Need HELP with Ubuntu on Droid X
This is a discussion on Need HELP with Ubuntu on Droid X within the Droid X Hacks forums, part of the Droid X Development category; i've been trying to run ubuntu on DX using problematic method HERE ... i run every command and script like he did... i got the ...
Results 1 to 1 of 1
Thread: Need HELP with Ubuntu on Droid X
    Points: 176, Level: 3
    Level completed: 52%, Points required for next Level: 24
    fruitpunk's Avatar
    56455
    Mar 2012
    i've been trying to run ubuntu on DX using problematic method HERE... i run every command and script like he did...
    i got the ubuntu.img HERE
    when i type bootubuntu on terminal emulator, i got this message:
    Code:
    $ su
    # bootubuntu
    You will require a password to access your desktops.
    Password too short
    Laika@/#:
    i don't even get a chance to set a password...
    when i type Xvnc -localhost -geometry 854x480 -depth 24 -deferupdate 0, i got this message...
    Code:
    Laika@/#: Xvnc -localhost -geometry 854x480 -depth 24 -deferupdate 0
    file directory '/usr/share/X11/fonts/Speedo/' not found - ignoring
    file directory '/usr/share/X11/fonts/Type1/' not found - ignoring
    file directory '/usr/share/X11/fonts/75dpi/' not found - ignoring
    file directory '/usr/share/X11/fonts/100dpi/' not found - ignoring
    then the process stop...
    i've tried many ubuntu image... same result...
    can someone help me? i really want to run ubuntu on my DX... T_T
    or maybe some guide to use Linux Installer on DX
    sorry for my bad english....
  1. Has Anyone Successfully Installed Ubuntu on their Droid X?
    By AdamTomaino in forum Droid X Hacks
    Last Post: 10-20-2011, 02:50 AM
  2. Ubuntu and the droid X
    By TRAGIC in forum Droid X General Discussion
    Last Post: 05-23-2011, 10:01 AM
  3. Droid X and Ubuntu
    By scottfree in forum Droid X General Discussion
    Last Post: 03-22-2011, 09:04 PM
  4. Droid X and Ubuntu
    By FromBBtoDroid in forum Droid X Help
    Last Post: 12-19-2010, 07:39 PM
  5. Can I Access my Music Library (Ubuntu) on my Droid X remotely?
    By AdamTomaino in forum Droid X Audio / Video
    Last Post: 07-15-2010, 09:15 PM
can i access my droid x in ubuntu 12
droid x ubuntu
droid x ubuntu install
install ubuntu droid x
install ubuntu on droid x
motorola droid x ubuntu
odroid-x ubuntu
run ubuntu on Droid X
ubuntu droid x
ubuntu on droid x
