Universal Androot: Another 1-click root method
This is a discussion on Universal Androot: Another 1-click root method within the Droid X Hacks forums, part of the Droid X Development category; How to: Root the DROID X Using Universal Androot | Droid Life: A Droid Community Blog...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Universal Androot: Another 1-click root method
    Points: 105,975, Level: 100
    Overall activity: 43.2%
    Garemlin's Avatar
    15
    Delaware
    3,831
    351 times
    Paycer likes this.
    Paycer's Avatar
    5782
    Omaha, Nebraska, USA
    6
    Bump.
    I tested this out two days ago on my brand new Droid X running 2.1 and it rooted it flawlessly. I also did it on my cousin's fiance's original Droid last night, (it's running on an OTA update of Froyo) and it worked for him as well. I downloaded it straight to the phone and rooted. I proceeded to install Free Wifi-Tether for Root Users and connected my iPod Touch 2G 32GB to his 3G connection without a hitch.
    This is essentially EasyRoot but it's entirely free. It supports a one-touch root+unroot and there are a couple other options. It doesn't give you the option to install BusyBox and whatnot like EasyRoot does, but you can just as easily get those from the Market, etc. Don't be lazy. You can save a log of the root process, so if it doesn't support your device or something goes wrong, you can find out what happened and message the developer with detailed information. There's also the option to execute a temporary root. You can root your device and do anything that requires root access, then be automatically un-rooted when you reboot your device.
    It's really quick, easy, simple, and completely free. I highly recommend it. Thank you for posting about it here, Garemlin.
    Points: 2,233, Level: 28
    Level completed: 56%, Points required for next Level: 67
    Overall activity: 1.8%
    DroidXXX's Avatar
    919
    214
    subscribed
    Droid X, Android version 2.3.3, System version 4.5.596 MB810
    Haigot's Avatar
    460
    11
    worked for me
    Points: 1,446, Level: 21
    Level completed: 46%, Points required for next Level: 54
    Overall activity: 0.0%
    airboss1998's Avatar
    598
    52
    +1. worked great with 2.1. Once I updated to 2.2, doesn't work (says it does, but wireless tether won't run).
    Points: 19,009, Level: 87
    Level completed: 32%, Points required for next Level: 341
    Overall activity: 4.3%
    250 Experience PointsCreated Album pictures100 Experience PointsThree FriendsTagger Second Class
    hollywood's Avatar
    2093
    Boise, ID
    1,371
    50 times
    Quote Originally Posted by airboss1998 View Post
    At the bottom of the Droid Life page (After step 5) it states:
    "Unrooting and backup instructions plus Droid X 2.2 ROM on the way!"
    So I am assuming it will be available soon after the 2.2 OTA update becomes available.
    The Droid was BORN great
    "Be not afraid of greatness. Some are born great, some achieve greatness, and some have greatness thrust upon them..." -William Shakespeare
    Rescue Squad
    Points: 30,292, Level: 100
    Overall activity: 3.4%
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,379
    330 times
    Interestingly enough I somehow got root. I used an SBF flash recovery after an attempted clockwork recovery did me wrong. I just got it back this morning and was dreading having to reload all the apps and re-set everything back up. Fired up Titanium Backup did not and could not get root so it shut down. So I know I did not have root at all.
    When I saw this thread I figured WTH I am a reflash pro now . Ran the progrm and it said it worked. But like the OP said, when I went back to T-Backup or SETCPU.... no root. I did no file manipulation at all on the system and was running the phone as normal setting things up. A bit later I figured I would do some cleaning up of the SDcard and fired up Rootexplorer by habit. What comes up? the su verification program and <granted root access>
    Wish I could tell you exactly what I did but, it is possible to do it.
    rj2's Avatar
    2787
    30
    i used it & updated to 2.2, lost root cuz i didnt move /su from bin to xbin
    sbf'd to 2.1, used androot again, moved /su and then updated to 2.2 & still have root this time. great one click option
    Points: 1,472, Level: 21
    Level completed: 72%, Points required for next Level: 28
    Deathshead's Avatar
    164
    122
    I did the same thing I wanted a nice clean 2.2 install so I .sbf back to 2.1, used androot awesome lil app, root explorer to move su and updated to keep root, phone is running amazing. Did the stage right mid for kicks too. Nice and quick..
    Points: 1,326, Level: 20
    Level completed: 26%, Points required for next Level: 74
    Overall activity: 0.6%
    Daybreak's Avatar
    412
    41
    Howdy,
    I used the universal androot. It worked very simply with a log file created. Then I installed root explorer, Gave it SU permission. Used root explorer to move SU from system\bin to the system\xbin folder. Booted into recovery, And applied the update zip. Froyo+ Root working fine here
    ~~ Later Mike
  1. One-click Root for your Droid X
    By wuyanks in forum Droid X News
    Last Post: 09-29-2010, 02:06 PM
  2. Replies: 30
    Last Post: 08-21-2010, 02:41 AM
  3. Where to find one click root?
    By bmwnick in forum Droid X Hacks
    Last Post: 08-20-2010, 02:39 PM
  4. Free one click root app?
    By supahrob in forum Droid X Hacks
    Last Post: 08-10-2010, 10:07 AM
  5. Root/un root with one click, without computer?
    By Nickdroid86 in forum Droid X Hacks
    Last Post: 08-03-2010, 09:35 PM
Universal Androot 2.2.1
androot 2.2.1
androot 2.3
androot 2.3.3
androot for 2.3.3
is universal androot safe
universal androot 2.2.2
universal androot 2.3
universal androot 2.3.3
universal androot 2.3.3 download
universal androot android 2.3.3
universal androot droid
universal androot droid x
universal androot for 2.3
universal androot for 2.3.3
universal androot method
universal root for 2.3.3
universalandroot 2.3
universalandroot 2.3.3
